"Oh no, Something has gone wrong, Logout"
(10-20-2020, 06:37 AM)jed Wrote: I've regularly updated my Braveheart after weeks of non-use and haven't encountered this issue.
This part of your post concerns me:
(10-19-2020, 11:10 PM)pajux Wrote: fixed some broken packages (hopefully fixed)
I suspect this is the cause of your problem.
  • Which packages were 'broken'?
  • Which repositories were you using?
Rolling release distributions are fallible, but I don't believe that failure to update regularly is the cause.
At the risk of being labelled an elitist, Manjaro isn't a good target to evaluate stability on. Try reinstalling the Mobian rootfs and let us know how it goes.
Good points, and I wasn't evaluating stability, rather explaining I saw the same error on both.
Meanwhile, I got Manjaro running on a newer release (because it downloaded faster than Mobian yesterday..) and was able to get it in a usable state, so next up will be Mobian.
And while I didn't note every package that was broken wrt Mobian, I can remember off the top of my head
 - pinephone-support  (some dependency was refusing to upgrade or install), which probably might explain some of the issues I encountered afterwards...
 - gnome-authenticator (some dependency was changed from python3-yoyo-migrations to python3-yoyo , and the migrations package was refusing to uninstall)
Eventually I uninstalled them and their troublesome deps and reinstalled the packages and their deps, successfully.
What repos was I using? Whatever default repos Mobian uses..
in either case, can't troubleshoot that further since the emmc has been reflashed already, all I can do now is reflash Mobian Smile
RE: "Oh no, Something has gone wrong, Logout" - by pajux - 10-20-2020, 05:26 PM
  Waydroid install instructions end up attempting to use wrong URLS to aquire .debs chainingsolid 1 3,457 04-26-2024, 04:56 PM
Last Post: zetabeta
  Time is wrong after reboots stucked at 27th august user641 2 2,927 09-08-2022, 01:39 PM
Last Post: user641
  22 July 2116 -- wrong Date & Time Anna 7 9,828 07-30-2021, 07:29 PM
Last Post: bcnaz
  Axolotl on Mobian. What am I doing wrong? quixote 3 4,924 05-11-2021, 06:09 PM
Last Post: quixote
  Wrong location / place by GPS - Location Services - GNSS - Maps Anna 17 19,518 03-22-2021, 12:42 PM
Last Post: Maus
  What am I doing wrong with Geary ? wi_badger 3 8,314 09-16-2020, 06:34 AM
Last Post: m.alizade7
