Tutorial: Run Debian off NVMe
(10-19-2020, 09:25 AM)wdt Wrote: That is parameters that are set before  uboot is compiled
strings u-boot.img  OR uboot,img will show about 4-5 pages of things inside uboot
Usually, not all that useful
the grep is for boot_targets, which is uboot search order
To change, you will have to compile uboot yourself
(BTW,, mmc1=SD,,,mmc0=emmc)
I have been looking, maybe there is a trick to "chain" extlinux.conf's, so far no
Other than renaming,, ie extlinux.conf ->extlinux.conf.bak,, that works (or rather, doesn't, ie won't find this one)
Just what are you trying to do?  Get a selector?
If so, the only one, so far, is samueldr's uboot, needs a patched kernel (until 5.9, patch will be mainline)
It does sort of work, 2-6 boot attempts needed, so can take a few minutes (this with unpatched kernel)
@wdt ok, I understand.  I was looking for a way to change the order without having to re-build and re-install uboot.
Tutorial: Run Debian off NVMe - by hive - 10-18-2020, 03:20 PM
RE: Tutorial: Run Debian off NVMe - by wdt - 10-18-2020, 08:27 PM
RE: Tutorial: Run Debian off NVMe - by hive - 10-19-2020, 07:18 AM
RE: Tutorial: Run Debian off NVMe - by wdt - 10-19-2020, 09:25 AM
RE: Tutorial: Run Debian off NVMe - by hive - 10-19-2020, 10:09 AM
Information levinboot tutorial clover 0 3,871 12-20-2020, 09:30 PM
Last Post: clover
  Lid Magnet Moving tutorial (with pictures) PineyMike 1 3,684 11-27-2020, 04:54 PM
  Deepin Desktop Installation (Fedora 32 Workstation) Tutorial Upokupo 2 5,159 11-04-2020, 07:19 PM
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 7,918 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 56,547 06-07-2020, 02:37 AM
Last Post: as400
  Setup power profile from nvme bootscript korneliuszo 2 10,958 02-11-2020, 11:02 AM
Last Post: korneliuszo
  How to fix keymap of ISO keyboard - default Debian desktop hmuller 10 15,438 01-15-2020, 03:34 PM
Last Post: chip ling
