Cannot boot from microSD
So my sdcard reader is deep in there it does have a spring tray so I use a backend of a tweezer or something that matches with strength the back of the sdcard and it took a bit but it clicked in and clicks all the time I have been doing this (you want to make sure the tool doesn’t end up in the slot too). If your card just falls out it isn’t in the tray. It’s far in there. Give that a shot because for a while I was wondering why I couldn’t boot.
The holder piece is just for enclosing the space (waterproof, dust) not for holding the sdcard.
Putting the card in one side goes half way the other side feels like it has much more space down and it bounces or loose, you will know just have patience doing it and placing it in.
Cannot boot from microSD - by pizzalovingnerd - 10-14-2020, 11:46 AM
RE: Cannot boot from microSD - by barray - 10-14-2020, 12:32 PM
RE: Cannot boot from microSD - by pizzalovingnerd - 10-14-2020, 12:44 PM
RE: Cannot boot from microSD - by pizzalovingnerd - 10-14-2020, 03:25 PM
RE: Cannot boot from microSD - by pjsf - 10-14-2020, 07:05 PM
RE: Cannot boot from microSD - by barray - 10-14-2020, 10:48 PM
RE: Cannot boot from microSD - by fritz - 10-15-2020, 06:59 AM
RE: Cannot boot from microSD - by pizzalovingnerd - 10-15-2020, 10:49 AM
RE: Cannot boot from microSD - by barray - 10-15-2020, 04:11 PM
RE: Cannot boot from microSD - by pjsf - 10-15-2020, 06:55 PM
RE: Cannot boot from microSD - by pizzalovingnerd - 10-31-2020, 07:01 PM
RE: Cannot boot from microSD - by fritz - 10-21-2020, 07:33 AM
  Pinetab2 stays dark / won't boot derco0n 0 1,832 07-13-2023, 11:44 AM
Last Post: derco0n
  Read speeds of microSD slot and eMMC bartgrefte 9 18,330 01-01-2021, 05:45 AM
Last Post: bartgrefte
  Blank display on boot kwyjibot 5 9,318 09-15-2020, 11:34 AM
Last Post: kwyjibot
