Latest firmware for PinePhone modem!
#58
(08-11-2021, 06:58 AM)bcnaz Wrote: <snip>
 ***  IF   I am using the same operating system as you are, > and my phone works,  and your phone does not ?
    WHY   ?
For me the simplest answer is usually the best answer.
Well...even my own phone's behavior is inconsistent with itself! That's the definition of "instability" in a system. The system include factors such as geographic position, the network/SIM card in use and the communications modulation and network in use (tower frequencies/spread spectrums 2G, 3G, 4G, etc.).
Even while using the same operating system, our software, including the configuration settings and history files that determine its behavior, is assuredly not exactly the same. Software installations and other histories often play a role in behavioral outcomes (including bugs). I assure you that, no matter how good the hardware design, there are hardware timing violations or signal integrity issues present too. Sometimes they result result in software behavioral differences.
(08-11-2021, 07:14 AM)zetabeta Wrote: i basically relay comments from matrix channel from some developers.
01.002.01.002 is the most recommended firmware. https://github.com/Biktorgj/quectel_eg25_recovery
01.003.01.003 is the most recent but buggy. https://github.com/Biktorgj/quectel_eg25...003.01.003
even with the 002 firmware, it's more or less buggy. so, none of the firmwares are totally stable.
edit:
i forgot this one, only for informative purposes. it may not apply to the pinephone directly!
https://git.teknik.io/gn0m3dio/EG25-G_GB...nch/master
Thanks, zetabeta!
I suspected that Biktorgj/quectel_eg25_recovery 01.003.01.003 might be considered to be a "testing" repository, but I guess there's no "stable" branch when it come to EG25G firmware! Cry
It sounds like they will all flash and flashing should all be reversible so I guess I'll try both 01.003.01.003 and 01.002.01.002 and see if either works better for me than 01.001.01.001.
RE: Latest firmware for PinePhone modem! - by calinb - 08-11-2021, 02:17 PM
  Movuan distribution for PinePhone merom 5 4,688 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,040 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 54,067 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,305 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 58,537 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 5,604 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 14,890 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 3,790 06-16-2024, 10:26 PM
  Possible Free Backup Carrier for PinePhone PineFone 0 3,683 06-13-2024, 03:45 PM
Last Post: PineFone
  Using Signal on PinePhone in mid-2023? dante404 47 45,147 05-03-2024, 02:19 AM
Last Post: dragonhospital
