Latest firmware for PinePhone modem!
#21
(11-03-2020, 07:49 AM)firefox-58 Wrote:
(11-03-2020, 05:53 AM)Ph42oN Wrote: I decided to try installing this in hopes of fixing modem issues (in fact i did it couple of weeks ago), but it did not. I cannot tell if it helps for that thing many others say, missing calls, because i never tried calls so much, but the issue of losing mobile data after waking up from sleep is still present.
Yepp,
absolutely no change on the problem of
- not receiving incoming calls
- losing mobile connection after wakeup
- modem completely without function after wakeup
Since weeks NO reliable incoming calls :-(
I have far less problem than you, I think, after wakeup. For sure occasionally things need a reboot. But for whatever reason I learned a long time ago that my wakeup routine must be
  1. push powerbutton
  2. wait till phone signal strength (and wifi if enabled) icons appear and get status on lock screen
  3. then scroll up phosh unlock screen and unlock
Otherwise I get the "dreaded" no data icon in the status bar and have yet to find a reliable cure for it except reboot. (It will also cure if WiFi was off, you enable it and it connects but that depends on being in a WiFi area.)
Similarly I receive all the incoming calls I expect and have had no moans from any contacts. I do receive few calls though - less than 1/day. But I do have a ritual after every reboot to go to Settings, Sound, and test both channels, then flick the bottom of the phone and check the mic signal meter moves. About half of the time the settings application crashes before completing all 3 steps - retry the Settings application as necessary. Often times it auto swaps to a Ping rather than "Front left" - in which case playing with the Phone/default option may recover things, or a reboot or a ...
RE: Latest firmware for PinePhone modem! - by dukla2000 - 11-03-2020, 11:39 AM
  Fedora + Phosh for PinePhone njha 77 204,007 01-14-2026, 12:22 AM
  Difficulty with openSUSE Tumbleweed Install PinePhone Beta danm1988 0 343 11-17-2025, 07:49 AM
Last Post: danm1988
  Movuan distribution for PinePhone merom 5 5,257 07-27-2025, 05:01 PM
Last Post: merom
  baremetal via Zig on PinePhone - JumpDrive help please WhiteHexagon 1 3,370 07-07-2025, 10:33 AM
Last Post: WhiteHexagon
  Slarm64 on PinePhone [Unofficial Slackware ARM - 64 bit] acid andy 40 57,609 12-28-2024, 12:19 AM
  Office applications for the Pinephone Peter Gamma 2 4,607 09-05-2024, 09:22 AM
Last Post: Peter Gamma
  Struggle to install LibreOffice on the PinePhone Peter Gamma 50 64,786 07-26-2024, 10:35 PM
  Why does Pine64 sabotage office on the Pinephone? Peter Gamma 5 6,022 07-04-2024, 07:34 AM
  Which word processor to choose for the Pinephone? Peter Gamma 16 16,397 06-22-2024, 07:28 AM
  Samba share on the Pinephone? Peter Gamma 0 4,040 06-16-2024, 10:26 PM
