X11 Forwarding mobian
How can I use X11 forwarding on mobian? I used it on servers so I have experience. In sshd_config it is enabled, -X is given on the client side, DISPLAY contains localhost:10.0 but evolution opens on the pinephone.
I try to setup evolution but there is a popup window and when I select the input field on it the virtual keyboard pops up and the text field looses focus so I cant fill it. I was thinking I can set it up using X11 forwarding, "running" evolution on my ubuntu machine.
X11 Forwarding mobian - by kovacsadam07 - 10-07-2020, 04:55 AM
RE: X11 Forwarding mobian - by LinAdmin2 - 10-07-2020, 10:50 AM
RE: X11 Forwarding mobian - by wibble - 10-07-2020, 12:51 PM
RE: X11 Forwarding mobian - by kovacsadam07 - 10-10-2020, 06:14 AM
RE: X11 Forwarding mobian - by sergio.pantalone - 12-12-2020, 05:54 PM
RE: X11 Forwarding mobian - by Zebulon Walton - 12-13-2020, 06:47 AM
RE: X11 Forwarding mobian - by Zebulon Walton - 12-13-2020, 12:16 PM
RE: X11 Forwarding mobian - by Zebulon Walton - 12-13-2020, 06:02 PM
RE: X11 Forwarding mobian - by sergio.pantalone - 12-13-2020, 06:44 PM
RE: X11 Forwarding mobian - by Zebulon Walton - 12-13-2020, 07:14 PM
RE: X11 Forwarding mobian - by 3x5co - 01-15-2021, 03:08 PM
RE: X11 Forwarding mobian - by Zebulon Walton - 01-22-2021, 05:26 PM
RE: X11 Forwarding mobian - by spaetz - 02-08-2021, 01:30 AM
RE: X11 Forwarding mobian - by Zebulon Walton - 02-08-2021, 08:03 AM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,851 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,468 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,212 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  No sound after Mobian upgrade arbocenc 1 750 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,093 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,316 09-24-2022, 08:01 AM
Last Post: dante404
  PinePhone running Mobian - Malware extraction? names_fold 1 1,615 01-24-2022, 12:00 PM
  Mobian updates for phosh steves 2 2,063 01-17-2022, 02:18 AM
Last Post: bcnaz
  Assists for running Mobian my PinePhone gilwood 0 1,584 01-01-2022, 04:38 PM
Last Post: gilwood
  ? vpn or tor for mobian rvh 9 7,160 12-02-2021, 05:58 PM
Last Post: b7l3wui26r
