Persistently mount SD card?
(11-19-2020, 04:30 PM)DarkManiels Wrote:
(11-12-2020, 04:57 PM)HLing Wrote: um, I think I need help. I was able to follow the mobian tweaks up until finding out the UUID:
Here's where I got confused. Can I just add the third line by typing in the UUID I got from sudo blkid /dev/mmcblk0p1?
At the moment, it looks like the sd card is there. My storage Usage has a "Storage 1(the size of my 32G sd card) with a Home folder having 581 MB,, and Storage 2 (my internal memory) with Operating system of 5.1GB.
I should not leave it as is, but I'm confused as to what the portions after each UUID should look like.
Please help!
It looks like you're following the directions from the wiki to mount an SD card as your home directory. I was looking for a way to persistently mount an SD card but keep my home directory on the eMMC, which is what @fernando_c_m helped me with. Sorry - I haven't tried those directions in the wiki, so I don't know how to answer your question. Hopefully someone else can help out, or you could ask as a separate question.
Thanks,  DarkManiels, for your reply.  I  misunderstood  then.  oops. My pinephone  is working fine  now. the 32G  card is   seen but not mounted. That's the good news.   The bad news is I messed up   my work desktop computer as a  result of carelessness  when I used Jumpdrive to  write  the fstab. (instead, the desktop fstab file got deleted, nothing  boots..
Persistently mount SD card? - by DarkManiels - 10-05-2020, 05:17 PM
RE: Persistently mount SD card? - by fernando_c_m - 10-06-2020, 04:00 AM
RE: Persistently mount SD card? - by DarkManiels - 11-08-2020, 01:45 PM
RE: Persistently mount SD card? - by HLing - 11-12-2020, 04:57 PM
RE: Persistently mount SD card? - by DarkManiels - 11-19-2020, 04:30 PM
RE: Persistently mount SD card? - by HLing - 11-21-2020, 08:28 PM
  APN settings not working with new operator SIM card user641 1 2,523 03-01-2023, 04:43 PM
Last Post: anonymous
  What does handle SD card automount? mdk 1 2,236 01-29-2023, 03:15 AM
Last Post: mdk
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 3,783 07-16-2022, 02:28 PM
Last Post: dachalife
  Apps and SD Card biketool 2 3,503 03-06-2022, 09:47 AM
  How to flash a µSD-Card with Balena Etcher walter1950 1 2,475 01-22-2022, 02:06 AM
Last Post: bcnaz
  How to insert a SIM-Card and/or a µSD-Card walter1950 0 1,790 01-21-2022, 02:46 PM
Last Post: walter1950
  When I set SD card as /home, PP can't complete boot nelstomlinson 4 5,055 12-27-2021, 03:06 PM
Last Post: nelstomlinson
  weird SIM card question RodneyMyers 4 7,063 10-16-2020, 01:47 PM
Last Post: ThrillGates
  Activating a sim card bcnaz 4 7,964 08-08-2020, 06:37 PM
Last Post: bcnaz
  Unable to mount exFAT file system jyc88 4 8,490 07-23-2020, 05:21 PM
Last Post: jyc88
