Persistently mount SD card?
I have Mobian installed on my eMMC and use a 128GB SD card to store my music collection. Unfortunately I've had troubles with various music players "losing" my music library after a while and having to re-scan or re-build it when I open the app after a few days (which can take quite a while). I believe I read somewhere that Mobian only mounts the SD card when it's needed, rather than keeping it persistently mounted, and I'm guessing this may be behind my problem.
I've read about the option to mount the SD card as an extended home directory in the tweaks section of the Mobian wiki, but I'm not sure I want to wipe my SD card and follow those directions just to see if this fixes my music problem. Does anyone know if there's a way to persistently mount an SD card without wiping it and setting it as the home directory? Or is this even something I'd want to do? Presumably there's a reason the card isn't persistently mounted in the "stock" Mobian installation. Any thoughts on the matter would be appreciated.
Persistently mount SD card? - by DarkManiels - 10-05-2020, 05:17 PM
RE: Persistently mount SD card? - by fernando_c_m - 10-06-2020, 04:00 AM
RE: Persistently mount SD card? - by DarkManiels - 11-08-2020, 01:45 PM
RE: Persistently mount SD card? - by HLing - 11-12-2020, 04:57 PM
RE: Persistently mount SD card? - by DarkManiels - 11-19-2020, 04:30 PM
RE: Persistently mount SD card? - by HLing - 11-21-2020, 08:28 PM
  APN settings not working with new operator SIM card user641 1 2,523 03-01-2023, 04:43 PM
Last Post: anonymous
  What does handle SD card automount? mdk 1 2,237 01-29-2023, 03:15 AM
Last Post: mdk
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 3,783 07-16-2022, 02:28 PM
Last Post: dachalife
  Apps and SD Card biketool 2 3,503 03-06-2022, 09:47 AM
  How to flash a µSD-Card with Balena Etcher walter1950 1 2,475 01-22-2022, 02:06 AM
Last Post: bcnaz
  How to insert a SIM-Card and/or a µSD-Card walter1950 0 1,790 01-21-2022, 02:46 PM
Last Post: walter1950
  When I set SD card as /home, PP can't complete boot nelstomlinson 4 5,055 12-27-2021, 03:06 PM
Last Post: nelstomlinson
  weird SIM card question RodneyMyers 4 7,063 10-16-2020, 01:47 PM
Last Post: ThrillGates
  Activating a sim card bcnaz 4 7,964 08-08-2020, 06:37 PM
Last Post: bcnaz
  Unable to mount exFAT file system jyc88 4 8,490 07-23-2020, 05:21 PM
Last Post: jyc88
