RockPro64 has bad Memory (Software sogfaults and kernel panics)
(11-19-2020, 12:27 PM)LMM Wrote:
(11-19-2020, 12:36 AM)wildering Wrote: I cracked open the two other boards and ran memtest on them with no errors reported. I then transplanted that eMMC module onto the date code 5219 board and ran the test again. I was presented with a slew of errors. It's evident that, that ROCKPro64 (v2.1, 2018-07-02 5219) is also defective and will warrant an RMA.
I ran memtest with Debian an it seems ok. (v2.1, 2018-07-02). What is noticeable is the high temperature reached (70°C) in spite of a heatsink. Then I put it over a fan and it dropped below 50°C after 9 min
I don't know if it is a good practice (and a good idea) but I cut the conductive pad in order to be able to double the layer on the DDR chip to make the contact with the heatsink. Otherwise it probably does not
I don’t see how doubling the conductive pad would hurt, but I imagine conductivity would be impacted. It shouldn’t be necessary though, as I’ve found a single layer makes good contact with the heat sync. Plus in my case I didn’t have the chance to do anything other than run apt update, which shouldn’t cause a temperature spike at all. Plus both other boards run at a cool 45-50 degrees under moderate load with the tall heat sync and no fan.
The most likely cause of the segmentation faults we’ve been experiencing is defective chips from the manufacturer or them breaking during product assembly.
RE: RockPro64 has bad Memory (Software sogfaults and kernel panics) - by wildering - 11-19-2020, 06:53 PM
  TPM module for rockpro64 misha64 0 1,638 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 6,732 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 1,936 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 33,934 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 1,574 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 3,034 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 10,324 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 1,929 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 8,335 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 3,541 05-27-2022, 06:51 PM
Last Post: justwantin
