RockPro64 has bad Memory (Software sogfaults and kernel panics)
(10-12-2020, 07:38 AM)richese Wrote: I tried to run the memtester on my board with fresh image and sure enough there seem to be memory issues in the part of memory it tested.
Resuts: https://pastebin.pl/view/00e8b2d7
Hardware I am using:
Rockpro64 V2.1 2018-07-02, 4GB variant, date code 52 19
running of SD card, tall heatsink installed, powered by Pine 5A power supply
For OS image I used ayufan's buster-minimal-rockpro64-0.10.12-1184-arm64 image.
I believe this one uses recent enough u-boot that does not use the binary blob in RAM.
Command used:
sudo memtester 3G 1
I tried the same on other SBC's I have with no errors so there is definitely something going on with this RockPRO board.
Sorry I just saw this. I did the same thing you did. I got a minimal Armbian image and run as root:
memtester 3400M 1
And I got DDR Errors. My RockPro64
Rockpro64 V2.1 2018-07-02, 4GB variant, date code 4719
RE: Kernel panic and seg fault issues? - by kop316 - 10-14-2020, 12:26 PM
  Powering two disks from RockPro64 some_pinephone_user 3 1,005 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 2,902 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 10,581 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 3,352 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 41,937 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 3,214 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 5,253 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 14,202 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 3,790 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 12,591 07-18-2022, 10:05 PM
Last Post: zer0sig
