PineA64 512 reboot - board shut down
(07-28-2016, 01:43 PM)Mohit B Wrote: Hi, I got my Pine A64+ 1GB with a Wi-Fi add on card. I bought an INR 300 worth duplicate Samsung power adapter rated 5V 2.0A. I also bought an 8GB Sandisk Micro SD Card Class 4. I am having following issues: 1. The default image for an 8GB SD Card on the Pine64 downloads link is not getting written on the SD Card. I tried with Win32 Disk Writer tool and it kept saying that the image size is more than the SD Card size. The SD Card when formatted under Windows 7 shows usable space of 7.2 GB. I then had to use the Phoenix Image and used the Phoenix Card utility to do the Android 5.1 image burn. It was successful. 2. After the first boot into Android the board, I configured my Wi-Fi and connected to the internet. I connected a wired mouse and keyboard. Downloaded Youtube. As soon I clicked to play the YouTube app the screen went blank. The HDMI signal for still there but nothing was happening. I re-booted the device by powering off and on. This time it showed me a message that Android apps are being optimized during boot. Few minuted after the boot the device turned off automatically. No mouse or keyboard was connected. I re-did the SD card with a fresh Android image but now I am having random screen going blank or the power LED itself going off after few minutes into the boot. I touched and realized that the A64 microprocessor was hot. Kindly provide me inputs in solving this, as I am already considering this as a failed investment. Also can you give details of the adapter that you are using Make, Model, Link to Buy and Price in India/Mumbai. This may be a power issue, but I am not sure. Please help. PS: It was dumb of me to buy the 1GB version, since later while searching the images I read that the Remix OS is suited for the 2GB version and will lag in performance on the 1GB model. Damn shame.
See my reply to this message in the other thread you posted it in, here.
RE: PineA64 512 reboot - board shut down - by Ghost - 07-28-2016, 02:07 PM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,486 10-06-2022, 08:46 PM
Last Post: ihab
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 2,302 09-03-2019, 11:57 PM
Last Post: hbaxmann
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,181 05-15-2019, 02:55 PM
Last Post: Thatoo
  Any success working with OpenCV on the PineA64? Tonny91 0 2,416 10-16-2018, 09:16 PM
Last Post: Tonny91
  My first Single Board! jjh221 4 6,631 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 4,319 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 3,462 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 2,248 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 8,762 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 3,195 01-15-2018, 11:21 AM
Last Post: Luke
