Pinecil -> Pinegun?
I registered just to bump this thread and let you know what a great idea it is/was.  I was going to register to create a new thread, but Avamander apparently had the same idea I did.  My TS100 has made soldering for a repair super easy.  I used to avoid fixing/making things because I didn't want to wait 5-10 minutes for my old weller to heat up.  The TS100 heats up in like 20 seconds so I can plug it in, so by the time I get things organized it's ready to go.  It's also great to have the ability to change heat settings great - board work and splicing wires require totally different heat settings.  It's great to KNOW that the iron is set up right for the job.  I'm looking forward to having a pinecil too (if they ever come back in stock) so I can keep different tips on the different irons.
I'd love for a similar upgraded experience for hot glue.  While 20 seconds probably isn't do-able to get a hot glue gun ready, it would be nice to have it ready in 45 seconds to a minute. My current gun probably takes 3-4 minutes or better.  I'd like to have the ability to set it for low temp glue vs high temp glue and get the temp just right.  I glue foamboard together for a strange variety of projects (RC Planes, theatre props, etc), and my current glue gun will melt the foam at it's 100w setting, but isn't hot enough at it's 60w setting... i usually wind up switching it between it's settings several times during my project.    Something like a 500w pinegun or pinehotglue or PineHoG with almost the same software as the pinecil would be WONDERFUL to have.  Please consider making one.  No one seems to make such a product.  Hot glue guns are mostly on/off devices, or 2 settings (hi/low) devices.  I did find one that has a horrible wheel thingee that doesn't really set a temp, just a potentiometer like many soldering irons had.  I think there would be a real market for a digitally temp controlled hot glue gun.
Pinecil -> Pinegun? - by Avamander - 09-28-2020, 05:50 PM
RE: Pinecil -> Pinegun? - by tllim - 09-30-2020, 03:17 PM
RE: Pinecil -> Pinegun? - by Avamander - 10-01-2020, 04:31 PM
RE: Pinecil -> Pinegun? - by joelspangler - 12-29-2020, 03:43 PM
RE: Pinecil -> Pinegun? - by Avamander - 01-04-2021, 03:52 PM
RE: Pinecil -> Pinegun? - by VaZso - 12-30-2020, 01:25 AM
RE: Pinecil -> Pinegun? - by kobiGA - 07-31-2021, 01:35 PM
RE: Pinecil -> Pinegun? - by ryo - 12-30-2020, 08:11 AM
RE: Pinecil -> Pinegun? - by joelspangler - 01-16-2021, 04:36 PM
RE: Pinecil -> Pinegun? - by Avamander - 01-17-2021, 01:39 PM
RE: Pinecil -> Pinegun? - by EternityForest - 02-05-2021, 03:21 PM
RE: Pinecil -> Pinegun? - by Marcos L - 02-19-2021, 12:16 AM
RE: Pinecil -> Pinegun? - by joelspangler - 05-18-2021, 08:30 PM
RE: Pinecil -> Pinegun? - by roel - 06-11-2021, 06:19 AM
RE: Pinecil -> Pinegun? - by Avamander - 07-04-2021, 05:20 AM
RE: Pinecil -> Pinegun? - by biketool - 07-05-2021, 04:51 AM
RE: Pinecil -> Pinegun? - by Avamander - 07-12-2021, 11:31 AM
RE: Pinecil -> Pinegun? - by rocketman - 10-12-2023, 07:54 AM
RE: Pinecil -> Pinegun? - by barkerxavierr - 01-09-2025, 02:10 AM
RE: Pinecil -> Pinegun? - by tllim - 01-12-2025, 09:37 PM
RE: Pinecil -> Pinegun? - by MonicaHSE - 01-17-2025, 02:26 AM
RE: Pinecil -> Pinegun? - by tllim - 01-21-2025, 01:09 PM
  Question about firmware updates on Pinecil V2 helengrace 1 464 10-16-2025, 10:41 PM
  incorporate a multimeter into the Pinecil kellanphil 2 2,200 08-13-2025, 01:14 AM
Last Post: lalisa12
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,117 08-27-2024, 08:01 PM
Last Post: drewdavis
Exclamation What is this - Pinecil V3? andrea6 2 14,777 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 2,690 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 2,850 04-22-2022, 07:01 AM
Last Post: bbeeast
  Pinecil Broken? skaaq 4 9,235 01-25-2021, 11:28 AM
Last Post: skaaq
  Pinecil stuck in shipping? mbreese 3 7,045 01-07-2021, 07:46 AM
Last Post: moxx
  Pinecil - Tip Disconnected molzy 2 6,981 01-03-2021, 07:21 AM
Last Post: molzy
  Pinecil arrived VaZso 0 3,118 12-28-2020, 10:36 AM
Last Post: VaZso
