USB-C Charging on the PBP?
#30
Is there a simple way to debug USB-C PD on the Pinebook Pro? I've (relatively) recently bought a powerbank with PD output, but it is a simpler and cheaper version (GreenCell PowerPlay20 Model: PBGC03) with max. 18W. There are two ways of charging PBP with it, using USB-C port or USB 3.0 port, but sometimes USB-C (on the powerbank side) doesn't work with PBP, if it happens I can charge using other ports or restart PBP. Sometimes USB-C on the PBP doesn't work at all and restart is needed. Sometimes USB-C charging works (but not from PD port on the powerbank) and the USB-C hub won't work (is not powered up by the PBP) without restart. Is a reboot necessary or is it enough to just reload a kernel module?
USB-C Charging on the PBP? - by Paulie420 - 09-24-2020, 09:13 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-24-2020, 09:52 PM
RE: USB-C Charging on the PBP? - by jiyong - 09-25-2020, 05:12 AM
RE: USB-C Charging on the PBP? - by as400 - 09-25-2020, 05:25 AM
RE: USB-C Charging on the PBP? - by wdt - 09-25-2020, 09:11 AM
RE: USB-C Charging on the PBP? - by as400 - 09-28-2020, 07:07 AM
RE: USB-C Charging on the PBP? - by Paulie420 - 09-25-2020, 10:53 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-25-2020, 06:46 PM
RE: USB-C Charging on the PBP? - by jiyong - 09-25-2020, 05:28 PM
RE: USB-C Charging on the PBP? - by bastafari - 09-26-2020, 09:49 AM
RE: USB-C Charging on the PBP? - by xmixahlx - 09-26-2020, 10:37 AM
RE: USB-C Charging on the PBP? - by Paulie420 - 09-26-2020, 12:03 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-27-2020, 12:14 AM
RE: USB-C Charging on the PBP? - by lot378 - 09-28-2020, 07:28 AM
RE: USB-C Charging on the PBP? - by as400 - 09-28-2020, 08:39 AM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-29-2020, 11:28 AM
RE: USB-C Charging on the PBP? - by bastafari - 09-29-2020, 12:25 PM
RE: USB-C Charging on the PBP? - by bastafari - 09-29-2020, 05:32 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-29-2020, 09:50 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-30-2020, 04:16 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-30-2020, 11:26 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-29-2020, 04:48 PM
RE: USB-C Charging on the PBP? - by Idaho - 09-30-2020, 01:05 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 10-01-2020, 09:00 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 10-02-2020, 09:02 AM
RE: USB-C Charging on the PBP? - by wdt - 10-01-2020, 11:03 AM
RE: USB-C Charging on the PBP? - by as400 - 10-02-2020, 02:33 AM
RE: USB-C Charging on the PBP? - by lot378 - 10-02-2020, 10:08 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 10-02-2020, 04:20 PM
RE: USB-C Charging on the PBP? - by wrzomar - 12-04-2020, 02:39 PM
RE: USB-C Charging on the PBP? - by xyzzy - 12-07-2020, 05:08 AM
RE: USB-C Charging on the PBP? - by wrzomar - 12-11-2020, 01:06 PM
RE: USB-C Charging on the PBP? - by xyzzy - 12-11-2020, 02:41 PM
RE: USB-C Charging on the PBP? - by wrzomar - 12-12-2020, 02:20 PM
Photo P{inebook Pro not charging Ome Ko 6 1,962 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,870 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,491 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,267 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,808 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,634 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,828 01-25-2021, 08:48 PM
Last Post: bchenlee609
  Charging via USB-C Port tyha 15 20,018 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,115 05-30-2020, 06:05 PM
  Charging via USB GloriousCoffee 7 8,640 04-03-2020, 12:01 PM
Last Post: GloriousCoffee
