USB-C Charging on the PBP?
>regular DC plug (3,5mm x 1,35mm)
No,, I just spent an hour, with a slightly lower quality vernier,,
3.3 x 1.25
It is quite hard to find smaller wires to measure ID (of plug),,
for sure,,,1.3 will not go in, 1.2 slightly loose
(a selection of beehive nails,, frame nails)
More measurements, more verniers, not consistent
probably type H,,,,3.4 x1.3
USB-C Charging on the PBP? - by Paulie420 - 09-24-2020, 09:13 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-24-2020, 09:52 PM
RE: USB-C Charging on the PBP? - by jiyong - 09-25-2020, 05:12 AM
RE: USB-C Charging on the PBP? - by as400 - 09-25-2020, 05:25 AM
RE: USB-C Charging on the PBP? - by wdt - 09-25-2020, 09:11 AM
RE: USB-C Charging on the PBP? - by as400 - 09-28-2020, 07:07 AM
RE: USB-C Charging on the PBP? - by Paulie420 - 09-25-2020, 10:53 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-25-2020, 06:46 PM
RE: USB-C Charging on the PBP? - by jiyong - 09-25-2020, 05:28 PM
RE: USB-C Charging on the PBP? - by bastafari - 09-26-2020, 09:49 AM
RE: USB-C Charging on the PBP? - by xmixahlx - 09-26-2020, 10:37 AM
RE: USB-C Charging on the PBP? - by Paulie420 - 09-26-2020, 12:03 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-27-2020, 12:14 AM
RE: USB-C Charging on the PBP? - by lot378 - 09-28-2020, 07:28 AM
RE: USB-C Charging on the PBP? - by as400 - 09-28-2020, 08:39 AM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-29-2020, 11:28 AM
RE: USB-C Charging on the PBP? - by bastafari - 09-29-2020, 12:25 PM
RE: USB-C Charging on the PBP? - by bastafari - 09-29-2020, 05:32 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-29-2020, 09:50 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-30-2020, 04:16 PM
RE: USB-C Charging on the PBP? - by moonwalkers - 09-30-2020, 11:26 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 09-29-2020, 04:48 PM
RE: USB-C Charging on the PBP? - by Idaho - 09-30-2020, 01:05 PM
RE: USB-C Charging on the PBP? - by MtnSk8 - 10-01-2020, 09:00 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 10-02-2020, 09:02 AM
RE: USB-C Charging on the PBP? - by wdt - 10-01-2020, 11:03 AM
RE: USB-C Charging on the PBP? - by as400 - 10-02-2020, 02:33 AM
RE: USB-C Charging on the PBP? - by lot378 - 10-02-2020, 10:08 AM
RE: USB-C Charging on the PBP? - by moonwalkers - 10-02-2020, 04:20 PM
RE: USB-C Charging on the PBP? - by wrzomar - 12-04-2020, 02:39 PM
RE: USB-C Charging on the PBP? - by xyzzy - 12-07-2020, 05:08 AM
RE: USB-C Charging on the PBP? - by wrzomar - 12-11-2020, 01:06 PM
RE: USB-C Charging on the PBP? - by xyzzy - 12-11-2020, 02:41 PM
RE: USB-C Charging on the PBP? - by wrzomar - 12-12-2020, 02:20 PM
Photo P{inebook Pro not charging Ome Ko 6 1,999 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 6,908 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,519 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,301 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,827 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,649 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,865 01-25-2021, 08:48 PM
Last Post: bchenlee609
  Charging via USB-C Port tyha 15 20,101 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,126 05-30-2020, 06:05 PM
  Charging via USB GloriousCoffee 7 8,690 04-03-2020, 12:01 PM
Last Post: GloriousCoffee
