Quick question about the SPDIF header
Hi all! I'd like to use the SPDIF pin on the 22-pin GPIO header to be able to do AC3 and DTS passthrough to my AV receiver over coax. I'm not trying to do optical out, and not trying to use an external DAC. The Rock64 is running Linux (libreelec) and I have an audio output device for SPDIF. Is it as simple as taking an RCA jack and just connecting the tip to the SPDIF pin and ring to a ground pin? Or is a more sophisticated circuit required for some reason? Thanks in advance!
.boom-extension-active{cursor: crosshair !important} .boom-extension-active *:hover{cursor: crosshair !important} .boom-extension-hovered-element{outline: 2px solid rgba(130, 170, 210, .6) !important} .boom-extension-expanded-element{background: transparent !important;border: 0 !important;float: none !important;margin-left: auto !important;margin-right: auto !important;padding-left: 0 !important;padding-right: 0 !important;position: relative !important;max-width: initial !important;min-width: initial !important;width: 100% !important;}
Quick question about the SPDIF header - by theophile - 09-24-2020, 04:07 PM
  Popcorn Hour Transformer header pinout yar 0 1,784 11-14-2020, 01:46 PM
Last Post: yar
  40 pin header GaryLa 5 7,071 01-07-2018, 11:58 AM
Last Post: GaryLa
  Thinking about byuing a Rock64 and some question before Osiander 2 3,366 12-22-2017, 02:15 PM
Last Post: Osiander
  Newbie question - should a Rock64 with no mmc card still output some video ? sgk 6 8,101 10-14-2017, 08:16 PM
Last Post: fusionneur
  Ship date question jl_678 65 55,997 10-05-2017, 01:01 PM
Last Post: Ak330ron
  Performance question - Rock64 vs A64+ vs RPi 3 jl_678 21 36,089 07-29-2017, 03:06 PM
Last Post: jl_678
