Pinebook Pro doesn't boot most of the time unless connected via USB-serial!
>>Why does reboot fail even though normal booting from SD works?
>With that PARTICULAR distro, on SD (what is it BTW), since its using its uboot
I'm using a minimal manjaro I've built a few days ago with u-boot 2020.07
>try a different one (the 1st uboot to "get the baton" is the one, all others ignored)
Do you mean I should a try different distro, or a different u-boot? If you're talking about different u-boot versions, where do I find them and how do I install them?
I thought that since manjaro is the distro that the current pinebook pros are shipped with, it would have the best support for the hardware.
>maybe serial cable alters timing slightly??
>I thought it was a bit random?
It is, you're right, but it boots most of the times using the serial cable, and it fails most of the times without.
>I still think mrfixits uboot is the best, updated of course
How can I try it out? Can I mix and match, mrfixits uboot with manjaro?
By the way, if you know of any good absolute beginners tutorial for u-boot, please pass it on.
Thanks once again!
RE: Pinebook Pro doesn't boot most of the time unless connected via USB-serial! - by nib0 - 09-27-2020, 10:21 AM
  Pinebook Pro Initial Impressions kunger 443 587,643 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,281 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 392 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 285 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 218 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 661 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 730 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 807 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 288 01-16-2024, 09:17 AM
Last Post: jbradley419
