Pinebook Pro- configuration aborts setting keyboard layout
Unfortunately, my Pinebook Pro remains unusable, despite the fact that I finally got it set up. There seems to be a couple different problems, and I'm not clear whether they are related.
The biggest problem seems to be with the function of the return key. When pressed, it seems to repeat. For instance, when I went to Firefox to access my home NAS, I was able to open a new tab, enter the web address and press return. However, when the login page comes up, it immediately begins logging in, despite the fact that I have not touched the keyboard since entering the web address.
More problematic, this problem has made it impossible to use the terminal as well. When I opened Konsole with the cursor, it opened without issue, waiting for my input. When I entered a sudo command and pressed RETURN, the terminal scrolled through three sudo password attempts before stopping and informing my about my three failed password attempts. On another occasion, I opened Konsole via Krunner using ALT + SPACE. I entered "konsole" into the search window and pressed RETURN. When the terminal window opened, it immediately started repeating the prompt, as if I was repeatedly pressing RETURN.
There also seems to be a problem, maybe not consistent, with the cursor randomly selecting items it passes over. I wondered if it might be a function of tap-clicking on the trackpad, but I am still having the problem when I use a USB mouse.
There is another issue that manifests as a rapid flickering, either of the cursor (in some circumstances), or of the address bar in Firefox when I attempt to click into the address of an existing tab. With the cursor, I am able to access the system settings (when something else isn't inadvertently selected). The cursor appears normal until I click in to the "input devices" setting pane, at which point it starts to rapidly flicker between the cursor, and the spinning disk of a busy system.
Any thoughts about what might be going on?
I have established that the MicroSD reader seems to work and when I restart with the card in, I get the Manjaro setup process, so I assume that I should be able to fetch a different image and try a different install if that is the best route forward to being able to use the PBP.
RE: Pinebook Pro- configuration aborts setting keyboard layout - by scroall - 10-04-2020, 06:43 PM
  Pinebook Pro vs Pinetab2 Lotech 0 468 02-13-2024, 08:57 PM
Last Post: Lotech
  When setting locale what is the code for the United states? Nobot 2 2,539 04-24-2023, 05:59 AM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,776 08-07-2022, 10:47 AM
Last Post: commiecam
  Keyboard layout dealie 0 1,577 08-27-2021, 12:55 PM
Last Post: dealie
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 4,210 07-14-2021, 02:49 PM
  First time user experiencing weird keyboard issues kendew 5 6,424 06-19-2021, 08:14 AM
Last Post: rotwang
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 4,054 05-25-2021, 11:05 AM
  Setup My Pinebook 64 and Lost Password jersdayoff 5 6,118 05-01-2021, 10:29 PM
  How to boot from SD card on pinebook pro linux123 3 6,328 12-02-2020, 10:29 AM
Last Post: linux123
  Setting up QT for compiling on my desktop vincer 0 2,139 09-19-2020, 03:31 PM
Last Post: vincer
