Let's talk about safety of Pinephone
(09-19-2020, 07:47 PM)lot378 Wrote: Bottom line? From what I reckon, to avoid a fire the PinePhone will need to use a different battery that has the right 10kOhm NTC (ideally, with 1% tolerance instead of 5% tolerance) for temperature sensing by the PMIC and larger capacity (by 50% or more) to fully support without compromise desktop convergence CPU 100% with all devices on and being used. The rest of the battle can then be met with PMIC configuration and software. It means a long-term solution, with Pine64 involved from the hardware point of view managing the risk, power costs, design changes, packaging etc.
It's interesting the schematic has an if this/or that for the 10kOhm NTC on TS so that particular issue was known.
I wonder why Pine64 chose to have batteries manufactured that have 3kOhm NTC instead of ordering them with 10kOhm NTC. A reason is compatibility with Samsung J7 batteries so anyone can obtain one locally. But that was a compromise and one that fails. Better to have the battery with the right NTC specification from the beginning, even if the capacity was still too low. That would have enabled the right building blocks to be in place for complete thermal oversight in the software.
In the short-term, I feel nothing except gratitude towards the tinkerers closely examining what's going on inside the PinePhone and providing their feedback.
I can foresee some experiments with replacing NTC on battery PCB or adding an NTC where it says NC on PinePhone PCB with 10kOhm to enable some tuning of PMIC and software. And may be jury-rigging up some other batteries to try them out, taking more measurements. Answering questions like does USB-C PD charging work at all?
The battery is user replaceable and is meant to be compatible with random samsung compatible batteries that the user can buy anywhere, not just from Pine64. So that's the reason for sticking with 3kOhm NTC, as Samsung batteries use that. If Pine used 10kOhm and people bought 3kOhm NTC batteries it would be a mess to support such situation. PMIC is programmable, so supporting 3kOhm NTC is not an issue. Yes, precision may be a little lower, because only ADC 8bits of the ADC output for voltage on NTC is used for the comparison against the limits.
The real issue here is that distros have to start caring about safety, and not take it as some upstream kernel/bootloader/hw manufacturer issue. It's the issue of the whole software/hardware package. Not sure how to achieve that, other than having users ask them what are they doing about it.
my website: https://xnux.eu
Let's talk about safety of Pinephone - by megous - 09-18-2020, 04:43 PM
RE: Let's talk about safety of Pinephone - by megous - 09-26-2020, 10:15 AM
Let's talk about safety of Pinephone - by eKeith - 09-20-2020, 08:11 AM
  PinePhone - boot from microSD laserpyramid 6 531 Yesterday, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 335 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 226 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,809 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,771 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 596 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,331 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 488 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,670 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,928 12-04-2023, 02:14 AM
Last Post: Peter Gamma
