brick after firmware update on emms
Some of those older manjaro distros had a problem with extlinux.conf,,
path needed to be adjusted, 3 places, make it ../dtbs/rock---,,, ../initramfs-li-----,,,, ../Image
IOW, the "../"
If you can mount on another computer and check.... but I see on emmc, a bit harder
Your post is a bit unclear....
RE: brick after firmware update on emms - by wdt - 09-19-2020, 10:48 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 1,998 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 969 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 983 02-22-2023, 03:23 PM
Last Post: robocone
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,830 10-08-2022, 06:22 PM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,142 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,366 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 2,006 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Updated stock Manjaro, now won't boot (brick?) pineymousepad 17 10,733 02-18-2022, 02:29 PM
Last Post: jiyong
  Wont charge when powered off, and update question pineymousepad 7 5,723 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 1,336 11-18-2021, 06:37 PM
Last Post: reundo
