WiFi signal weak
I think there are definitely driver issues, as I have had noticeable differences on three different builds.
UBPorts worked fine except for disconnecting once in awhile, but signal strength was good.
Arch/phosh had very weak signals from the same source(s).
Arch/plasma has good signal and good control.
All tested from the same location. Plasma is my favorite so far. touch screen works great and has a good linux look to it.
David
de KL7JKC
WiFi signal weak - by kelbot - 09-17-2020, 02:40 PM
RE: WiFi signal weak - by kelbot - 09-27-2020, 10:49 AM
RE: WiFi signal weak - by guenther - 09-27-2020, 04:32 PM
RE: WiFi signal weak - by kelbot - 09-27-2020, 08:07 PM
RE: WiFi signal weak - by guenther - 09-28-2020, 06:10 AM
RE: WiFi signal weak - by kelbot - 10-06-2020, 09:20 PM
RE: WiFi signal weak - by guenther - 10-07-2020, 02:40 AM
RE: WiFi signal weak - by Algot - 10-08-2020, 08:11 AM
RE: WiFi signal weak - by Jeffersoniantoo - 10-10-2020, 03:24 PM
  Pinetab 2 just arrived + when can hope to se wifi driver LRP 15 17,694 02-28-2024, 05:03 AM
Last Post: Surehand53
  Pinetab2 without Wifi a comfort extra? Schlucker 8 7,773 07-14-2023, 03:09 AM
Last Post: gregb49
  No WiFi or Ethernet on vanilla PineTab 2 from the factory? SmittyWerbenyegermanjenson 6 5,774 06-06-2023, 05:26 PM
Last Post: fxc
  Wifi adapter not found after update failed jojuma 0 1,433 01-22-2023, 05:15 PM
Last Post: jojuma
  kernel crash on wifi initialization javier.pb 0 2,839 12-30-2020, 08:01 AM
Last Post: javier.pb
