update programmed crashes
(09-18-2020, 03:44 AM)jed Wrote:
(09-18-2020, 12:24 AM)patrickmollohan Wrote: sudo apt remove gnome-authenticator
followed by
sudo apt install gnome-authenticator
It's worth noting that apt-get (and by extension, apt) has a reinstall alias:
# man(1) apt-get: reinstall is an alias for install --reinstall
sudo apt reinstall gnome-authenticator
Good tip! However, this didn't work for me either. As with @wasgurd's post above, apt reinstall didn't fix the issue.
EDIT:
Not sure why @"jed" downvoted me over this statement. I said it was a good suggestion, even though it wasn't the right fix. Someone's got their panties in a bunch.
update programmed crashes - by RodneyMyers - 09-17-2020, 01:14 PM
RE: update programmed crashes - by Helium75 - 09-17-2020, 01:33 PM
RE: update programmed crashes - by RodneyMyers - 09-17-2020, 03:42 PM
RE: update programmed crashes - by Helium75 - 09-17-2020, 09:48 PM
RE: update programmed crashes - by Helium75 - 09-18-2020, 03:27 AM
RE: update programmed crashes - by RodneyMyers - 09-18-2020, 06:51 AM
RE: update programmed crashes - by patrickmollohan - 09-18-2020, 08:27 AM
  how to update mobian over tor vusra 13 5,710 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 911 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,036 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 3,166 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 3,462 11-28-2022, 03:30 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 7,335 10-14-2022, 05:38 PM
Last Post: Krafter
  Wifi issue since last update and held back updates goku499 11 4,264 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,542 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 3,970 09-05-2022, 12:10 AM
  Loving latest Mobian Update drh 11 4,159 08-22-2022, 12:19 PM
