Stable build and updates
Mobian is rolling release, as it uses the testing and unstable repositories.
The 'stable' releases are largely a misnomer: they should be considered stable as an image to install, not as an in-place release, ala Debian stable.
The moment you upgrade, you are in-step with the nightly build.
Stable build and updates - by ergo owl - 09-17-2020, 10:01 AM
RE: Stable build and updates - by User 18618 - 09-18-2020, 03:38 AM
RE: Stable build and updates - by ergo owl - 09-18-2020, 06:35 PM
RE: Stable build and updates - by User 18618 - 09-19-2020, 06:59 AM
  No volume control after latest updates Zebulon Walton 19 6,970 09-08-2023, 08:28 AM
Last Post: jessencan
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,277 08-31-2023, 12:38 PM
Last Post: vusra
  Haven't seen updates in a while Zebulon Walton 3 1,224 06-24-2023, 04:29 PM
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,734 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,628 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,236 09-21-2022, 02:39 PM
  How to check which mobian build I am running jojuma 0 726 08-29-2022, 04:44 AM
Last Post: jojuma
  Glacially slow system updates on Mobian - waiting on boot 20m - 1h bujiraso 5 3,275 03-01-2022, 10:06 AM
Last Post: bujiraso
  I built a reminder app but can't seem to build a deb/snap/flatpak for it, help? ragreenburg 9 6,744 09-10-2021, 02:51 PM
Last Post: ragreenburg
  No updates after upgrade? jojuma 3 2,755 08-26-2021, 08:53 PM
Last Post: bcnaz
