Rockpro64 RAM issues
(09-19-2020, 02:08 PM)tllim Wrote:
(09-15-2020, 02:40 AM)sausal Wrote: Hi All,
What methods are you using to test memory? I have clear Debian install(not depends what distribution is used) and when the bigger size of memory is allocated with memtester and shows multiple failures.
The same not depending from power source 12v3A and 12v5A was tested:
debian@rockpro64:~/linux-build$ sudo memtester 3000M
memtester version 4.3.0 (64-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffffffffffff000
want 3000MB (3145728000 bytes)
got  3000MB (3145728000 bytes), trying mlock ...
locked.
Loop 1:
  Stuck Address       : setting   0
ok
  Random Value        : ok
  Compare XOR         : ok
  Compare SUB         : ok
  Compare MUL         : ok
FAILURE: 0x00000001 != 0x00000000 at offset 0x02b11878.
FAILURE: 0x00000002 != 0x00000003 at offset 0x02b11880.
FAILURE: 0x00000002 != 0x00000003 at offset 0x02b11888.
FAILURE: 0x00000000 != 0x100000000 at offset 0x58553c38.
FAILURE: 0x00000001 != 0x00000011 at offset 0x58553c40.
FAILURE: 0x00000002 != 0x1000000002 at offset 0x58553c48.
FAILURE: 0x00000002 != 0x1000000002 at offset 0x59654278.
FAILURE: 0x00000003 != 0x4000000003 at offset 0x59654280.
FAILURE: 0x00000001 != 0x00000005 at offset 0x59654288.
FAILURE: 0x00000001 != 0x00000000 at offset 0x597542b8.
FAILURE: 0x00000001 != 0x00000041 at offset 0x597542c0.
FAILURE: 0x00000001 != 0x00000041 at offset 0x597542c8.
FAILURE: 0x00000002 != 0x400000012 at offset 0x597544c0.
FAILURE: 0x00000003 != 0x400000013 at offset 0x597544c8.
FAILURE: 0x00000003 != 0x4000000003 at offset 0x598544b8.
FAILURE: 0x00000001 != 0x100000001 at offset 0x598544c0.
FAILURE: 0x00000000 != 0x00000040 at offset 0x598544c8.
FAILURE: 0x00000003 != 0x1000000043 at offset 0x59954088.
  Compare DIV         : FAILURE: 0x6bfc31142fff05e5 != 0x6bfc31152fff05e5 at offset 0x58553c38.
FAILURE: 0x6bfc31142fff05e5 != 0x6bfc31142fff05f5 at offset 0x58553c40.
FAILURE: 0x6bfc31142fff05e7 != 0x6bfc31542fff05e7 at offset 0x59654280.
FAILURE: 0x6bfc31142fff05e7 != 0x6bfc31142fff05e5 at offset 0x596d3e78.
FAILURE: 0x6bfc31142fff05e5 != 0x6bfc31142fff05e7 at offset 0x596d3e80.
FAILURE: 0x6bfc31142fff05e7 != 0x6bfc31142fff05f7 at offset 0x597544c0.
FAILURE: 0x6bfc31142fff05e7 != 0x6bfc31142fff05f7 at offset 0x597544c8.
FAILURE: 0x6bfc31142fff05e7 != 0x6bfc31542fff05e7 at offset 0x598544b8.
FAILURE: 0x6bfc31142fff05e5 != 0x6bfc31152fff05e5 at offset 0x598544c0.
FAILURE: 0x6bfc31142fff05e7 != 0x6bfc31142fff05e5 at offset 0x598d43f8.
Why I am testing is that Debian crashes during regular operations. Rsync is not usable including any other higher load tasks which finishes with random backtraces.
Please install meemtester and check out memory stability.
sudo apt-get install memtester
sudo memtester xxxxM
For 2GB Board xxxx = 1700
For 4GB Voaes xxxx = 3700
I am having the same issues:
https://forum.pine64.org/showthread.php?tid=11714
Support at Pine is unfortunately terrible, and I had to open up a paypal dispute.
Rockpro64 RAM issues - by sausal - 09-15-2020, 02:40 AM
RE: Rockpro64 RAM issues - by aleksei - 09-17-2020, 09:27 AM
RE: Rockpro64 RAM issues - by tllim - 09-19-2020, 02:08 PM
RE: Rockpro64 RAM issues - by kop316 - 10-16-2020, 03:06 PM
RE: Rockpro64 RAM issues - by mstevens - 11-30-2020, 04:10 AM
RE: Rockpro64 RAM issues - by tllim - 12-06-2020, 12:09 AM
  Installing Wifi drive for the RockPro64 John45595 0 302 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 747 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 679 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,239 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 883 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,315 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,812 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,638 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,011 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,779 10-21-2022, 07:44 AM
Last Post: rapier1
