VS Code running on PineTab
(09-15-2020, 12:05 PM)brentashley Wrote:
(09-15-2020, 03:42 AM)m.alizade7 Wrote:
(09-12-2020, 04:58 PM)brentashley Wrote:
(09-12-2020, 02:48 PM)m.alizade7 Wrote: Do i need to do some steps before this? Because i am getting failures.
What failures are you getting? Just worked for me, not sure if other changes I had made prepared it to work.
if you cut and pasted, you may have got the abbreviated link that the forum software created
the full link is as below (but without the space)
https://  github.com/cdr/code-server/releases/download/v3.5.0/code-server-3.5.0-linux-arm64.tar.gz
 I am getting No Authentication & Not serving HTTPS.
That sounds like what the server tells you when it is working properly (we told it to use no authentication did not request HTTPS).  Keep that terminal window open and change to the browser, then go to 127.0.0.1:8080 and that should connect the browser to the VSCode server and bring up the editor interface.
Sorry for a late reply, but I did it today and it worked!
VS Code running on PineTab - by brentashley - 09-12-2020, 01:29 PM
RE: VS Code running on PineTab - by m.alizade7 - 09-12-2020, 02:48 PM
RE: VS Code running on PineTab - by brentashley - 09-12-2020, 04:58 PM
RE: VS Code running on PineTab - by m.alizade7 - 09-15-2020, 03:42 AM
RE: VS Code running on PineTab - by brentashley - 09-15-2020, 12:05 PM
RE: VS Code running on PineTab - by m.alizade7 - 10-15-2020, 08:07 AM
RE: VS Code running on PineTab - by Lex-2008 - 09-13-2020, 02:31 PM
RE: VS Code running on PineTab - by brentashley - 09-13-2020, 08:04 PM
  Pinetab2s running DanctNIX just got Bluetooth!! biketool 0 72 Yesterday, 04:45 AM
  PineTab (early adopters) wifi broken in kernel 6.12 bartgrefte 0 1,128 03-23-2025, 05:25 AM
Last Post: bartgrefte
  PineTab 2 login screen rotation fix chzbacon 11 12,371 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 5,898 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 3,542 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 5,369 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 10,637 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 41,074 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 1,855 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 207,968 04-26-2022, 11:58 AM
Last Post: thomzane
