VS Code running on PineTab
(09-12-2020, 02:48 PM)m.alizade7 Wrote: Do i need to do some steps before this? Because i am getting failures.
What failures are you getting? Just worked for me, not sure if other changes I had made prepared it to work.
if you cut and pasted, you may have got the abbreviated link that the forum software created
the full link is as below (but without the space)
https://  github.com/cdr/code-server/releases/download/v3.5.0/code-server-3.5.0-linux-arm64.tar.gz
VS Code running on PineTab - by brentashley - 09-12-2020, 01:29 PM
RE: VS Code running on PineTab - by m.alizade7 - 09-12-2020, 02:48 PM
RE: VS Code running on PineTab - by brentashley - 09-12-2020, 04:58 PM
RE: VS Code running on PineTab - by m.alizade7 - 09-15-2020, 03:42 AM
RE: VS Code running on PineTab - by brentashley - 09-15-2020, 12:05 PM
RE: VS Code running on PineTab - by m.alizade7 - 10-15-2020, 08:07 AM
RE: VS Code running on PineTab - by Lex-2008 - 09-13-2020, 02:31 PM
RE: VS Code running on PineTab - by brentashley - 09-13-2020, 08:04 PM
  PineTab 2 login screen rotation fix chzbacon 11 3,590 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 1,899 02-24-2024, 12:29 PM
Last Post: Evergreen
  Working OS on pinetab RISC-V? user641 3 630 12-13-2023, 08:11 AM
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,040 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,262 08-05-2023, 05:08 PM
Last Post: bingch
  Arch Linux ARM on PineTab 1 Danct12 25 29,175 06-10-2023, 05:33 PM
Last Post: fxc
  PineTab 2 Login Failure cptijerina 0 654 06-07-2023, 07:16 PM
Last Post: cptijerina
  PineTab Mobian bcnaz 150 143,927 04-26-2022, 11:58 AM
Last Post: thomzane
  Xmonad on PineTab Telefza 0 1,777 06-24-2021, 04:04 AM
Last Post: Telefza
  PineTab Mobian Upgrade issue - Pin no longer works thomzane 3 4,033 04-30-2021, 06:52 AM
Last Post: thomzane
