Removing Back to PineTab
(09-11-2020, 08:14 PM)publiclewdness Wrote: Does the back of the PineTab just pop off like the back of the PinePhone ? I figured it best to ask before I try it as I don't see any noticible notch to pop off like the PinePhone has. I tried searching DuckDuckGo for breakdown guides but found none. I don't plan on any upgrades yet but want to add an M.2 SSD down the road so it will be good to figure out.
 You can remove it by inserting a fingernail (or plastic pick) at the corners, but it's much stiffer than the pinephone cover, and seems to be providing a lot of structural support to the unit. Replacing it is also quite tricky, especially around the magnet and pogo pin area, I had some internal issues to fix so took mine apart - the second time I broke the digitizer, so you probably want to avoid that.
Removing Back to PineTab - by publiclewdness - 09-11-2020, 08:14 PM
RE: Removing Back to PineTab - by pjsf - 09-11-2020, 08:27 PM
RE: Removing Back to PineTab - by publiclewdness - 09-11-2020, 09:34 PM
RE: Removing Back to PineTab - by tllim - 09-17-2020, 11:41 PM
RE: Removing Back to PineTab - by pjsf - 09-17-2020, 11:49 PM
RE: Removing Back to PineTab - by tllim - 09-19-2020, 02:45 PM
  Not able to power on PineTab anymore zkajdan 4 3,530 01-12-2025, 10:38 PM
Last Post: vatin
Question Will Pinetab 2 spare parts be available? vatin 6 5,672 12-09-2023, 01:31 AM
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 1,840 09-28-2023, 01:06 PM
Last Post: dynobang
  [Tutorial] How to overclock Pinetab 2 Darth-Apple 0 2,604 09-25-2023, 08:45 AM
Last Post: Darth-Apple
  External Reset button on PineTab V? michaelengel 0 1,663 09-18-2023, 06:31 AM
Last Post: michaelengel
  PineTab2 screen won't turn back on until reboot KelsonV 3 3,710 08-23-2023, 09:08 AM
Last Post: diederik
  Pinetab 2 screen no longer coming on Fibonacci 9 8,949 06-30-2023, 08:26 AM
Last Post: Purple_Illusion
  Pinetab completely bricked Saksmito 8 7,310 06-10-2023, 04:23 PM
Last Post: fxc
  What RISC-V chip will the PineTab-V use? msm 2 3,435 04-05-2023, 06:58 PM
Last Post: msm
Big Grin Howto: Pinetab Screen Replacements (+ Pictures) RTP 5 10,242 02-10-2022, 08:31 PM
Last Post: barray
