How to boot from USB?
The booting is a bit complex, compared to x86/x64, as the x86/x64 BIOS hides a lot of the CPU booting issues. ARM & ARM64 don't have a standard BIOS, yet. We use U-Boot which is pretty primitive still, (though progressing).
So, the chip used in the Pinebook Pro is a Rockchip RK3399 SoC and only boots from specific devices, starting with the first. If that device does not have software loaded, then the CPU moves on to the next device. Here are the devices: SPI NOR, eMMC, SD & USB OTG. That USB OTG is NOT a normal boot. I don't understand it, but my understanding is that it won't boot a USB flash drive.
That leaves a Micro SD card as your best bet. If you don't have one, then you basically NEED one for any recovery.
However, the software in the SPI NOR or eMMC "may" allow booting to a normal USB flash drive. BUT, and be very clear it's a MAYBE, it's up to the software version loaded on SPI NOR or eMMC. (And then the distro on the USB flash drive needs to support USB too.) Booting off normal USB flash drives was a highly desired feature, and has been added to the U-Boot used on many Pinebook Pro Linux distros.
Eventually we will see better initial booting support. I have tested a version of U-Boot with more features, including NVMe support and boot time display menu, but it's not stable.
Arwen Evenstar
Princess of Rivendale
How to boot from USB? - by kendew - 09-10-2020, 07:25 PM
RE: How to boot from USB? - by Arwen - 09-11-2020, 10:44 AM
RE: How to boot from USB? - by xmixahlx - 09-11-2020, 01:49 PM
RE: How to boot from USB? - by wdt - 09-11-2020, 09:19 PM
RE: How to boot from USB? - by kendew - 09-23-2020, 04:34 PM
RE: How to boot from USB? - by MarcoRss87 - 10-07-2020, 03:25 PM
RE: How to boot from USB? - by wdt - 10-07-2020, 07:57 PM
RE: How to boot from USB? - by Arwen - 10-08-2020, 07:06 AM
  unable to boot after manjaro update gega 6 8,256 10-28-2022, 01:18 PM
  Minimum daughter boards/peripherals required for main board to boot cmicallef 5 9,203 03-12-2021, 10:10 PM
Last Post: cmicallef
  Pinebook Pro Boot Issues - Booting needs multiple attempts mtndew 13 27,911 10-04-2020, 08:55 AM
  Upgrade eMMC card - boot problems alpopa 0 3,983 09-16-2020, 12:31 PM
Last Post: alpopa
  Reboot, and halt and boot, are not the same regivanx 0 3,125 09-14-2020, 02:20 PM
Last Post: regivanx
  PBP not booting screen blank after SD card boot Jakobp 10 22,669 08-18-2020, 08:56 PM
Last Post: trinapicot
  Boot problems with new 128GB eMMC module Kareema 1 5,264 05-31-2020, 10:36 AM
Last Post: Kareema
  Changing Boot Order on the PineBook Pro bb1netusaf2004 1 6,220 05-17-2020, 02:17 PM
Last Post: Arwen
  Adding the NVME causes boot loop? swulff 7 17,555 12-20-2019, 08:11 PM
Last Post: Arwen
  "Pinebook Serial Console" unreliable, inhibits boot, kills WiFi and SD Solra Bizna 9 20,816 12-06-2019, 09:53 PM
Last Post: Solra Bizna
