nvme drive disappears after about an hour of uptime
#23
Thank you for checking.  Did you actually turn the laptop off and on while testing the behavior of those two SMART parameters?  A reboot alone, without powering off and on, might not be enough for those two parameters to be reset by the NVMe drive.
Speaking about the two available power inputs, the barrel port and the Type-C PD port, PineBook Pro can actually draw a slightly higher current from the barrel port, compared with the Type-C PD port.  That's the way the PineBook Pro's internal charging circuitry is actually configured.  With that in mind, using the barrel port is actually less likely to cause any power-related issues.
It would be great if you could manage to perform the additional testing, as you've described it.  Previous reports on the issues caused by the instability of PCIe Gen2 speed had different error messages than yours, but everything can be checked only through the additional testing.
RE: nvme drive disappears after about an hour of uptime - by dsimic - 01-17-2021, 10:01 PM
  New Working nVME gilwood 0 195 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,487 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,776 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,257 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,856 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,837 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,585 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,605 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,728 07-09-2021, 08:45 PM
Last Post: moonwalkers
  NVME SPI Update not booting SD Card WZ9V 5 6,354 10-18-2020, 08:36 PM
