nvme drive disappears after about an hour of uptime
It is really strange that reinserting the ribbon cable makes the NVMe drive to appear again, but it may very well be caused by the excessive lenght of the ribbon cable.  What is the revision of the NVMe adapter you're using, the first revision (with the wider PCB), or the second revision (which has a narrow PCB)?
In a pinch, you could try applying some hot glue to the ends of the ribbon cable, where they meet the PCB connectors, to stop the cable from accidentally becoming loose.  I know, it may look messy, but I've seen hot glue even in some high-end products, so it should be good enough for the PineBook Pro. Smile
I've continued the investigation you started, and it seems that APST (Autonomous Powe State Transition) issues with NVMe drives, unfortunately, are pretty much here to stay, depending on the actual NVMe drive and the system it is used in.
Could you, please, run the tests with all power states disabled, so we can establish that as a stable configuration?  After that, I'd suggest that you change the "nvme_core.default_ps_max_latency" setting to have only the lowest power state disabled, and re-run the tests.  If that ends up in instability, have the latency setting changed to have two lowest power states disabled, re-run the tests, etc.
I know, it's a lot of work, but should be helpful for other users.  I've also added a link to this thread to the PineBook Pro wiki page(s).
Edit: According to the Linux kernel NVMe driver source, only a single Toshiba NVMe SSD has confirmed APST-related issues.  However, we clearly see that more drives are affected on certain systems.  By the way, please make sure that the PCIe link in your PineBook Pro runs at Gen1 speed, as described here.
Edit #2: You may also try using pure alcohol to clean the ends of the ribbon cable.  Before applying hot glue, of course. Smile
RE: nvme drive disappears after about an hour of uptime - by dsimic - 01-17-2021, 01:04 AM
  New Working nVME gilwood 0 213 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,527 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,808 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,373 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,895 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,853 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,716 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,634 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,784 07-09-2021, 08:45 PM
Last Post: moonwalkers
  NVME SPI Update not booting SD Card WZ9V 5 6,402 10-18-2020, 08:36 PM
