nvme drive disappears after about an hour of uptime
(09-19-2020, 03:02 PM)codebreaker Wrote: I no longer think that heat is my problem. I returned the two Intel drives and bought a sarent Rocket Q  2tb drive, installed it, and have the exact same issue.
After installing, I set up an ext4 partition, mount it, and then run the following command:
sudo dd if=/dev/zero of=/dev/nvme0n1p1 bs=1M status=progress conv=fdatasync
This is the one that hangs all the time. Not sure what to do next.
If you use dd on a mounted partition, I think you'd get undefined behavior, likely crashes. When I've accidentally dd'd to the wrong device (mounted /boot and /) in the past its caused a system crash.
Otherwise, it could still be a temperature thing, could also have to do with power draw. Maybe try lowering the power setting as xmixahlx suggested - my previous comment has an example systemd service to do that.
And as an aside, my thermal padding rig has been working well, no more crashes so far.
RE: nvme drive disappears after about an hour of uptime - by elijahr - 09-21-2020, 10:44 AM
  New Working nVME gilwood 0 206 02-12-2024, 08:46 AM
Last Post: gilwood
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,513 04-04-2023, 12:16 PM
Last Post: globaltree
Thumbs Up NVMe adapter, Great addition dachalife 2 1,799 11-28-2022, 12:56 PM
Last Post: dachalife
  NVMe drives not detected mattpenn 12 10,326 03-05-2022, 04:53 AM
Last Post: mattpenn
  NVme intall usage? tkudog 2 2,883 03-04-2022, 01:29 AM
Last Post: Tazdevl
  Anyone selling a spare NVMe adapter in Europe? tom.tomasz 1 1,848 01-03-2022, 07:57 AM
Last Post: tom.tomasz
  NVMe-related crashes and instability, plus a solution simonsouth 13 14,662 12-10-2021, 07:47 PM
Last Post: josmo
  NVMe SSD testing methodology halogen 1 2,619 07-22-2021, 05:57 PM
Last Post: calinb
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,768 07-09-2021, 08:45 PM
Last Post: moonwalkers
  NVME SPI Update not booting SD Card WZ9V 5 6,386 10-18-2020, 08:36 PM
