Getting platform tools working like I'm used to?
@bastafari , check this wiki entry: https://wiki.archlinux.org/index.php/Android#Fastboot
Fastboot works for me with sudo.
Will check if android-udev solves the issue with the permissions (once the PBP decides to boot... unfortunate side effect from trying the bleeding edge)
[UPDATE]: Install android-udev and restart. Fastboot should work without the need of using sudo and it will fix adb not connecting when the device is in charging only mode.
Device: Pinebook Pro 128GB No:246 / MainOS: Manjaro ARM
Godot and Flutter - creating something can be fun with the right tools!
RE: Getting platform tools working like I'm used to? - by PakoSt - 09-07-2020, 04:57 PM
  No Android build working! pin 60 116,013 07-03-2021, 06:08 PM
Last Post: justiceankomah
