Status update 2020-09-05
(09-08-2020, 07:29 PM)TheLastDon Wrote: <snip>
I'd like to help QA for you at first and then help fix some of the problems. Where should I enter bugs? At this issues page? https://gitlab.com/mobian1/issues/-/issues
Generally speaking if it's an upstream bug it's probably better suited in the affected programs issue tracker.
If it has to do with hardware specific bits or configuration/packaging where we are upstream (see the packages page)
it should go into our gitlab.
When you have problems with a package that comes from Debian you might want to use the "reportbug" tool.
If you are unsure, you can open an issue at our gitlab or ask us on the matrix channel.
(09-08-2020, 07:29 PM)TheLastDon Wrote: I've noticed a lot of annoying little issues in the settings dialog that are probably pretty easy to fix and would add great value if they are fixed. Thanks again!
If it's an upstream issue, it would be best to go to the source: gnome-control-center
@Helium75 Have you looked at this thread and the linked issue within yet?
Status update 2020-09-05 - by a-wai - 09-05-2020, 09:08 AM
RE: Status update 2020-09-05 - by ragreenburg - 09-05-2020, 10:20 AM
RE: Status update 2020-09-05 - by DingDangDoong - 09-05-2020, 11:21 AM
RE: Status update 2020-09-05 - by bitnick - 09-05-2020, 12:00 PM
RE: Status update 2020-09-05 - by LMalilil - 09-05-2020, 02:21 PM
RE: Status update 2020-09-05 - by Hiraghm - 09-08-2020, 10:08 AM
RE: Status update 2020-09-05 - by TheLastDon - 09-08-2020, 07:29 PM
RE: Status update 2020-09-05 - by Helium75 - 09-08-2020, 09:53 PM
RE: Status update 2020-09-05 - by devrtz - 09-10-2020, 09:56 AM
RE: Status update 2020-09-05 - by dukla2000 - 09-10-2020, 05:39 PM
RE: Status update 2020-09-05 - by a-wai - 09-11-2020, 01:23 AM
RE: Status update 2020-09-05 - by dukla2000 - 09-11-2020, 03:20 AM
RE: Status update 2020-09-05 - by SwordfishII - 09-11-2020, 03:54 AM
RE: Status update 2020-09-05 - by Cree - 09-12-2020, 12:50 AM
RE: Status update 2020-09-05 - by SwordfishII - 09-12-2020, 04:18 AM
RE: Status update 2020-09-05 - by Hiraghm - 09-12-2020, 09:59 PM
RE: Status update 2020-09-05 - by gizmuth - 09-11-2020, 10:50 PM
RE: Status update 2020-09-05 - by a-wai - 09-12-2020, 04:00 AM
RE: Status update 2020-09-05 - by gizmuth - 09-20-2020, 12:35 PM
RE: Status update 2020-09-05 - by dukla2000 - 09-22-2020, 02:41 PM
RE: Status update 2020-09-05 - by HLing - 09-23-2020, 07:31 AM
RE: Status update 2020-09-05 - by fernando_c_m - 09-23-2020, 08:45 AM
RE: Status update 2020-09-05 - by dukla2000 - 09-23-2020, 12:47 PM
RE: Status update 2020-09-05 - by HLing - 09-23-2020, 04:17 PM
RE: Status update 2020-09-05 - by dukla2000 - 09-25-2020, 03:24 AM
RE: Status update 2020-09-05 - by dukla2000 - 10-01-2020, 02:01 PM
RE: Status update 2020-09-05 - by dukla2000 - 10-12-2020, 01:50 PM
  trixie update poll questions suggestions j_s 5 467 10-22-2025, 07:14 AM
Last Post: anonymous
  how to update mobian over tor vusra 14 15,352 12-04-2024, 07:01 PM
Last Post: vusra
  Mobian repository status henrythemouse 16 18,304 04-10-2024, 10:02 AM
Last Post: diederik
  Wifi doesn't work after update nickolas 2 3,350 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 11,694 02-26-2023, 01:01 PM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 10,299 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 11,919 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 3,998 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 10,411 09-05-2022, 12:10 AM
