Does anyone know where the scale to fit information is store?
(09-06-2020, 10:54 AM)ragreenburg Wrote:
(09-06-2020, 08:26 AM)spaetz Wrote:
(09-05-2020, 06:58 PM)ragreenburg Wrote:
(09-05-2020, 04:54 PM)spaetz Wrote:
(09-04-2020, 07:33 PM)ragreenburg Wrote: What I mean is when I type in scale-to-fit firefox-ers on, where does that information get stored so that the phone knows to keep it that way?
https://source.puri.sm/Librem5/phoc/-/bl...to-fit#L26
Sorry, I should have been more clear. I mean store on the phone. I looked at their script and it has a path in it that I certainly can't find on Mobian of /sm/Puri/phoc/application/
Yes, it uses gsettings (the equivalent of the windows registry) and you can get and set these entries using the command I linked above. It *is* where scale-to-fit save the info as the list is part of the scale-to-fit source.
I am still a bit confused on where I can find this information on my phone though. Because I made an app that scales everything but realized that without being able to check and see if they are already scaled it'd be impossible for it to know what is and isn't scaled.
You should be able to check the value using dconf, such as:
sundog@sundog-pinephone-lxde-emmc:~$ dconf read /sm/puri/phoc/application/firefox-esr/scale-to-fit
true
Also,
dconf dump /
should show you all the values stored in the database
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
RE: Does anyone know where the scale to fit information is store? - by sundog - 09-11-2020, 10:03 AM
  Make scale setting persistent 3x5co 2 2,143 10-26-2021, 05:57 PM
Last Post: 3x5co
  Software store crashes LMalilil 3 4,464 09-28-2020, 10:13 AM
Last Post: ThrillGates
  Global scale-to-fit? DarkManiels 5 7,684 09-03-2020, 05:02 PM
Last Post: DarkManiels
  anyone notice that scale-to-fit works on some apps, but not others? arturo2bodegas 1 2,793 08-01-2020, 10:58 AM
Last Post: bcnaz
  Video output scale after update 14/07/2020 antiX-Dave 3 4,660 07-16-2020, 04:32 AM
Last Post: a-wai
