Lid magnet missing?
Well, I opened the bezel and found the magnet. It is indeed very magnetic, so I'm not sure what the problem could be. Is it possible that the magnet is too strong for the hall sensor? Or that the polarity is reversed?
For anyone curious the bezel is actually pretty easy to remove. I'm sure it's much easier with the display assembly detatched from the main body, but I was able to gain access to the magnet without doing so. The rubber bumper at the top needs to be removed to gain access to a screw, and from there just carefully pry from the top corner downward with a credit card (or whatever) until you get to the bottom.
Magnet inside bezel (Imgur link)
Now that I've laid eyes upon it and confirmed that there is indeed a magnet there, I'm curious to know if anyone has any suggestions on how to fix this issue with lid closed sleep. As I said in my previous post, it DOES work, just when the lid is open about an inch. Fully closing the lid causes the PBP to wake up again. Huh
Lid magnet missing? - by ModemBlaster - 08-28-2020, 06:35 PM
RE: Lid magnet missing? - by pfeerick - 08-28-2020, 07:11 PM
RE: Lid magnet missing? - by ModemBlaster - 08-28-2020, 07:19 PM
RE: Lid magnet missing? - by Arwen - 08-29-2020, 08:47 AM
RE: Lid magnet missing? - by ModemBlaster - 08-31-2020, 12:25 PM
RE: Lid magnet missing? - by tllim - 09-03-2020, 10:43 PM
RE: Lid magnet missing? - by Arwen - 09-04-2020, 11:35 AM
RE: Lid magnet missing? - by subalpine - 09-07-2020, 06:24 PM
RE: Lid magnet missing? - by subalpine - 09-07-2020, 11:18 PM
RE: Lid magnet missing? - by Arwen - 09-08-2020, 06:47 AM
RE: Lid magnet missing? - by KC9UDX - 09-08-2020, 07:10 AM
RE: Lid magnet missing? - by subalpine - 09-08-2020, 12:12 PM
RE: Lid magnet missing? - by KC9UDX - 09-08-2020, 03:34 PM
RE: Lid magnet missing? - by subalpine - 09-08-2020, 09:19 PM
RE: Lid magnet missing? - by Arwen - 09-09-2020, 02:58 PM
RE: Lid magnet missing? - by brett - 09-10-2020, 07:51 PM
RE: Lid magnet missing? - by KC9UDX - 09-11-2020, 06:13 AM
RE: Lid magnet missing? - by Arwen - 09-11-2020, 11:18 AM
RE: Lid magnet missing? - by PineyMike - 10-13-2020, 08:39 AM
  wifi missing some networks filip 0 534 03-11-2023, 03:21 PM
Last Post: filip
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,366 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  wlan0 missing dex357 6 7,378 06-08-2020, 09:01 AM
Last Post: dex357
  Missing Screws missingchip 2 4,015 06-06-2020, 04:08 PM
Last Post: missingchip
  Pinebook missing screw from the factory tso4ev 4 5,631 01-20-2020, 01:25 PM
Last Post: Arwen
Thumbs Up Pinebook Pro Fingerprint Magnet neilman 28 28,033 12-04-2019, 10:13 PM
Last Post: Jeremiah Cornelius
