battery usage
You can buy the charger and get a Samsung EB-BJ700BBC battery - just cut the tabs off the bottom with a sharp knife. Here's the relevant Wiki page.
Community Edition models have recesses for the tabs, but for a Braveheart you need to cut them off.
The Samsung battery is slightly taller than the included battery. It fits, but can be difficult to remove; I made a makeshift pull tab with tape to ease removal.
battery usage - by HLing - 08-28-2020, 12:08 PM
RE: battery usage - by User 18618 - 08-28-2020, 01:00 PM
RE: battery usage - by HLing - 08-28-2020, 01:17 PM
RE: battery usage - by User 18618 - 08-29-2020, 06:04 AM
  Battery problem with a Pinephone keyboard and Mobian elode 2 4,691 12-22-2022, 07:10 PM
Last Post: acid andy
  Possible solutions to the battery draining issue? 3x5co 5 6,463 11-28-2022, 10:58 AM
Last Post: 3x5co
  Will this battery-saving script cause problems? rp3 1 2,951 08-28-2022, 02:00 PM
  Battery Management jsch 4 4,895 07-27-2022, 11:17 AM
Last Post: jsch
  Electricty Usage Efficiency food 7 9,022 09-18-2021, 01:17 PM
  Limiting battery charging to some percentage TRS-80 3 5,841 08-22-2021, 01:02 AM
Last Post: bcnaz
  Increasing max voltage to use a bigger battery SocialNetworkingWasAMistake 4 6,892 06-09-2021, 09:59 AM
Last Post: wibble
  Possible fix for lousy standby battery life? bitnick 5 8,366 02-04-2021, 04:05 PM
Last Post: dcinoz
  SMS after dead battery antiX-Dave 4 9,264 06-05-2020, 08:11 PM
Last Post: antiX-Dave
