strange keyboard behaviour, is it faulty?
Hey All,  Spent ages trying to solve this one and still no closer to getting it solved.
Bought PinebookPro, ansi keyboard at the end of 2019. This problem has been happening for ages. Due to covid etc I haven't gotten to looking at this for ages.
Would appreciate if anyone knows what's going on, or if the keyboard is faulty.
* On boot using an external keyboard everything is fine
* As soon as any key is pressed on the internal keyboard, it goes to uppercase and gets stuck there. Numbers only type the shifted items (!@#$% etc)
* Running showkey (https://linux.die.net/man/1/showkey) and pressing left shift once keeps saying that 'keycode 42 press', which is left shift key. It's not physically stuck though and pressing it shows press and release for it as well.
Pressing any other key stops the constant stream of 'keycode 42 press', but still behaves as if it's stuck.
Only a reboot fixes it and lets me type normally on the external kb again.
I've updated using jackhumbert firmware updater from github, tried this several times and still no joy. In desperation I tried the ISO keyboard version, that doesn't show the shift stuck behaviour. Going back to ansi and it reverts to the shift stuck behaviour.
Would really appreciate any tips on how to solve this, or even if it's possible.
strange keyboard behaviour, is it faulty? - by rdmarsh - 08-27-2020, 06:57 PM
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 129,833 09-13-2023, 03:43 AM
Last Post: k3dAR
  Hardware makes a strange pop noise. Gemeindepirat 7 2,945 08-12-2023, 01:59 AM
Last Post: User 27258
  Separate ISO keyboard for PBP Besouro 0 702 06-04-2023, 02:51 PM
Last Post: Besouro
Information Keyboard Duplicate Keypress Fix RjraymondDuplicate 0 1,111 02-17-2022, 11:52 PM
Last Post: RjraymondDuplicate
  keyboard and usb ports not working User 24565 3 2,679 02-15-2022, 10:12 AM
  Replacing the Keyboard gabb 6 6,463 01-11-2022, 07:39 AM
Last Post: Valenoern
  power on PBP if your keyboard is dead? stozi 0 1,331 11-29-2021, 01:55 PM
Last Post: stozi
  Replacement scissor switches (ANSI keyboard)? zackw 3 3,838 08-09-2021, 09:20 PM
  Some keyboard keys not working oddsocks 10 10,778 04-20-2021, 08:33 AM
Last Post: dsimic
  Spare parts / keyboard mbreese 2 4,213 01-07-2021, 07:40 AM
Last Post: dsimic
