FLOSS pinebook pro linux set-up
Sorry, I was wrong with my previous post as I learned later in a different thread. I can confirm that the built-in display DOES work without a firmware blob. It only seems to be needed to get the external display working. See also this thread:
https://forum.pine64.org/showthread.php?tid=12534
I am pretty sure external display would work with a usb adapter as well if you find one that works without blobs. However, I am not familiar in this "market". Do you have a particular model in mind?
Edit: Regarding other blobs - I am not sure whether u-boot ships a blob for training the DDR4 RAM and there is also something for using DRM in the trusted firmware repo. I've heard about some script to clean this repo (comparable to linux-libre) but I did not test this myself.
FLOSS pinebook pro linux set-up - by misha64 - 08-24-2020, 03:11 PM
RE: FLOSS pinebook pro linux set-up - by kuleszdl - 09-05-2020, 03:30 PM
RE: FLOSS pinebook pro linux set-up - by penaman - 01-14-2021, 12:51 PM
RE: FLOSS pinebook pro linux set-up - by kuleszdl - 01-14-2021, 04:05 PM
  Debian on Pinebook Pro u974615 8 456 03-22-2024, 03:57 PM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,141 02-22-2024, 04:02 PM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 210 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,923 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,983 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,704 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,014 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 4,935 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,329 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,428 08-07-2023, 01:12 PM
Last Post: myself600
