PBP won't boot (no amber or green LED)
#20
It sometimes is good (or at least reassuring) to know that someone else has experienced a problem similar to what you are having.  On Friday of this past week (August 21, 2020), I turned my PBP on and let it run for a while.  I also connected the charging cable in case some update needed a little more power from the battery.  There were several updates that were completed without any problem (that I know of).  When I turned the PBP off after an hour or two, maybe a bit longer, the power indicator showed a little over 95% charge.  Today when I attempted to turn it on again, the power button seemed to work as it should.  The power LED was first amber then turned to green.  But the screen was still black.  There was no log-in screen at all.  I tried some of the tools that could be used to get into the log-in screen and then to the desktop.  All without any change or success.  In a few minutes, I will print, from another computer, the file referenced and attempt that recovery method.  Thanks to the community for the responses to the newly found problems and for finding at least 'work around' solutions until the problem could be corrected at its source.
James Good
RE: PBP won't boot (no amber or green LED) - by James Good - 08-23-2020, 02:24 PM
  Cant boot into an OS trashtendenz 1 172 09-09-2024, 12:38 PM
  3 days in, slow/stuck or no boot. lgmpbp2 30 2,678 09-05-2024, 08:49 AM
Last Post: lgmpbp2
  Unable to boot? YossiS 4 202 09-04-2024, 10:35 AM
  upgrading u-boot--what version? where to get it? bsammon 11 2,115 05-22-2024, 09:33 AM
  uboot wont boot to SD card after upgrade jbradley419 7 1,982 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 586 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 3,479 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 1,342 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 988 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,802 09-19-2023, 08:48 AM
Last Post: dachalife
