USB-C hw mod tested
Feeling megi proximity I have got enough bravery to follow instructions to test OTG on PinePhone v1.2 (hw mod).
I have to say it WORKS!!! Big Grin
  • The longest part was to unscrew cca 15 little screws. Wink
  • Remove (unsolder) faulty pieces.
  • Put Ondřej's prebaked kernel with modules and u-boot config.
  • Put frimware and init it.
Voilà! USB-hub and mini-keyboard are working right away. Smile
As I didn't find any third party confirmation about proposed sequence is complete and correct, I here by confirm it works.
@Luke you may count Prague is covered. Wink
Note: with Ondřej's kernel I observe minor side effects at least with SXMO: battery driver reporting behavior changed, some scripts/programs with hardcoded ttySn got confused, USB-net doesn't start on boot.
USB-C hw mod tested - by Dmytro - 08-04-2020, 03:20 AM
RE: USB-C hw mod tested - by Dmytro - 08-07-2020, 08:52 AM
