New UBports edition - black screen (backlight) only
(08-03-2020, 09:50 PM)SwordfishII Wrote:
(08-03-2020, 09:45 PM)BBreeziN Wrote:
(08-03-2020, 09:43 PM)SwordfishII Wrote:
(08-03-2020, 07:17 AM)BBreeziN Wrote:
(08-03-2020, 03:56 AM)drpi Wrote: Flicker is a known problem at boot time.
Keep your phone connected on the charger for some time. Then try to boot it again.
Thanks for the fast reply, but it's not just flickering anymore, the screen never comes on at all. I left it plugged in overnight, but it still will not do anything (no LEDs, backlight, nothing) without being plugged in. It kind of seems like there are two issues here, the screen not working, and now the battery not charging or working.
Might be a silly question... But did you pull out the plastic tab covering the battery terminals?
You have to pop the back cover and remove the plastic barrier on the battery. Seems like that would cause the screen to not work and the battery to not charge if it's still in place.
Yes I did. It was holding a charge, running off the battery, and indicating a 90% battery during the 1 or 2 boot cycles where the screen was actually working. Any other ideas?
Bad battery or the orientation of the battery is wrong maybe. Do you have a multimeter to check the battery and the pins on the phone while plugged in?
If not you could get a new battery to eliminate or more likely confirm the battery as the issue
4.1 volts on the battery disconnected. I plugged in the phone without the battery and see a pulsing 4.2 volts on the pins. Now, for whatever reason, it's powering up again (I'm seeing the LED sequence) with the battery only, not plugged in. I hear the auto focus click on startup too, but still just a black backlit screen, no image.
RE: New UBports edition - black screen (backlight) only - by BBreeziN - 08-03-2020, 10:24 PM
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 369 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,325 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls on Pine Phone Beta convergence edition polypode 1 1,167 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Screen dying already? marcih 153 144,667 02-23-2023, 04:14 AM
Last Post: Shatur
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 23,816 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 19,922 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
  Screen Replacement Instructions erikkugel 4 3,126 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,621 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,724 07-03-2022, 06:27 AM
Last Post: Avisando
Question Upgrading a 2020 Community Edition Pinephone? danimations 5 3,626 03-10-2022, 08:18 AM
Last Post: danimations
