Why two power ports on a budget laptop??
#50
(08-12-2020, 12:00 AM)wdt Wrote: I guess maybe you are unlucky, the tolerances stacked against you
From charger chip pdf
Blinking at 0.5 Hz when fault occurs, including charge suspend,input over voltage,timer fault and battery absent.
OK, so the battery is definitely not absent, and since the IC is supposed to handle up to 17V input (unless I misread the sheet) there is no input overvoltage. So that leaves charge suspend and timer fault. For charge suspend the conditions appear to be the temperature but like I've said before (I believe) I've accounted for that with extra cooling to the battery and that didn't change anything. Admittedly I don't quite understand the conditions for the timer fault though, but that appears to me to have something to do with voltage levels, thresholds, and battery response to charger current, which makes me think it may have something to do with power drawn directly from the battery and possibly throwing off the IC measurements. Again, I'm no electrical engineer, if there is one here I'd be glad if they picked this apart.
This message was created with 100% recycled electrons
RE: Why two power ports on a budget laptop?? - by moonwalkers - 08-12-2020, 03:02 PM
  Pinebook Pro on Debian 12 Power Issue u974615 1 327 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,459 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,903 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,453 09-26-2022, 12:17 AM
Last Post: jonasd
  keyboard and usb ports not working User 24565 3 2,674 02-15-2022, 10:12 AM
  Blinking red light for charger, no power-on bifo 11 13,740 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,326 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,088 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 17,447 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,125 12-16-2020, 09:24 AM
Last Post: dsimic
