Why two power ports on a budget laptop??
(08-03-2020, 04:28 AM)jiyong Wrote: There is a problem that because of security, some devices no longer work properly with all chargers.
One example is my Yi 360 camera, that I can only charge with a cheap USB-A to USB-C adapter cable, as I can no longer charge directly from a USB-C charger.
Funny detail is that my phone refuses to charge with that cheap USB-A to USB-C adapter cable.
But in general I'm really happy with USB-C.
Now I only need one charger for my laptop and phone.
And even when I forget to bring a charger, there is someone around with a USB-C charger.
And that's the crux of the issue with power delivery over USB type C - the variety of power delivery specifications and chance that even if that charger has type C connector it's not quite compatible with your device because of the limits on the voltage and current it can deliver. And then there are some devices for which USB power delivery is a complete no-go due to their power requirements, like gaming or mobile workstation laptops that need more than 100W of power. With a dedicated power supply that just provides fixed voltage and up to fixed current none of those are an issue, though yes you'd have to carry one with you instead of relying on someone else having one handy for you to borrow.
Of course, neither of the above should be of much relevancy in PBP context, though even there I found out that I have two different USB cables where one charges the laptop almost as fast as the dedicated charger (not quite though), and another provides barely enough current to charge the laptop when it's idle.
You don't want to use the barrel port - don't use it, you don't want to pay for barrel port - look for a laptop without one. I, for one, like my barrel port because it allows me to use the single type C port without resorting to docks and dongles, so equivalent replacement for no barrel port would be two type C ports, which I'm certain would be more expensive than one type C and one charging port. And most importantly, I always know that if the power supply is rated for 5Vx3A with correctly sized connector and polarity then I don't need to still worry about the USB cable I use to connect it to the laptop, it'll always charge at ~15W.
This message was created with 100% recycled electrons
RE: Why two power ports on a budget laptop?? - by moonwalkers - 08-03-2020, 08:03 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 304 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,395 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,837 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,389 09-26-2022, 12:17 AM
Last Post: jonasd
  keyboard and usb ports not working User 24565 3 2,655 02-15-2022, 10:12 AM
  Blinking red light for charger, no power-on bifo 11 13,682 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,318 11-29-2021, 01:55 PM
Last Post: stozi
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,054 07-28-2021, 01:04 PM
Last Post: mjc
Question UK Power Supply User 11436 11 17,396 02-09-2021, 12:30 PM
Last Post: dieselnutjob
  Pinebook Pro Dock Power Requirements calinb 9 12,091 12-16-2020, 09:24 AM
Last Post: dsimic
