Phone doesn't boot after latest kernel update
I did a apt upgrade yesterday evening (about 24h ago) and saw that the only package to update the kernel was. After the update was done I rebooted the phone and it only showed a black screen.
I was running off of EMMC but I still had an older version on my SD. So I put that in, updated it and it wouldn't boot either.
I have an unmodified Braveheart. When I try to boot the phone I see the green LED, the screen lights up black for a few seconds, it turns off, I hear the clicking from the camera and that's it. When I leave the phone running it gets pretty hot. I cannot reach it over WiFi.
Tomorrow I will try to put the latest image on the SD and see what happens then.
Actually, I can reach it via WiFi. I'll see if I can get some more information out of it.
dmesg shows the error
[   12.096839] anx7688 1-0028: boot firmware load failed (you may need to flash FW to anx7688 first)
[   12.120840] anx7688 1-0028: power disabled
[   12.120896] anx7688 1-0028: spurious status irq
Phone doesn't boot after latest kernel update - by Boern - 07-22-2020, 03:04 PM
  The program doesn`t detect the camera blag0rag 2 321 02-15-2024, 08:03 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,987 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 928 09-29-2023, 11:29 PM
  No volume control after latest updates Zebulon Walton 19 7,096 09-08-2023, 08:28 AM
Last Post: jessencan
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,106 09-05-2023, 11:16 AM
Last Post: nickolas
  Mobian boot failed with zstd message after upgrade. Mahgue 0 632 09-01-2023, 11:29 AM
Last Post: Mahgue
Big Grin An early xmas present: 6.1 kernel treebeard 28 9,874 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to update mobian over tor vusra 13 6,876 07-09-2023, 08:57 PM
Last Post: vusra
  how to disable ipv6 at kernel level with towboot? vusra 2 896 07-09-2023, 01:25 AM
Last Post: vusra
  Stability problems with 6.1 kernel Zebulon Walton 9 2,574 05-12-2023, 08:09 AM
Last Post: zetabeta
