Mobian Mobile Data Doesn't Work
(07-22-2020, 12:18 PM)jyc88 Wrote: Have you tried using the latest nightly build or installing the most recent updates?
I was having issues with data not working in builds from early/mid July where trying to enable mobile data in settings would bring me to the page to select an access point, but the list would be empty. Some of the updates from July 21 seem to have fixed this for me though.
I think that the build I am using is from 15/16th and is a nightly build that I have just been updating everyday. I have been trying the data again every day and have been having the same problem with the access point list being empty - that still seems to happen occasionally - restarting usually solved that, but still no data.
However I seem to have solved it. I tried again after the latest update last night, same result - no data. But although both GiffGaff and Virgin say that the Password field should be left blank, on a whim I entered "password" as the password. Both phones on both networks worked immediately after that, and I have had no problems since. So I can now use data on Mobian!
Mobian Mobile Data Doesn't Work - by pablo180 - 07-22-2020, 09:22 AM
RE: Mobian Mobile Data Doesn't Work - by jyc88 - 07-22-2020, 12:18 PM
RE: Mobian Mobile Data Doesn't Work - by pablo180 - 07-23-2020, 08:18 AM
RE: Mobian Mobile Data Doesn't Work - by pablo180 - 07-23-2020, 08:48 AM
  Mobian repository status henrythemouse 16 8,715 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,965 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 127 03-18-2024, 08:54 PM
Last Post: penguins_rule
  The program doesn`t detect the camera blag0rag 2 317 02-15-2024, 08:03 PM
  Mobile internet via cellular network mostly not working Anna 18 10,217 01-19-2024, 02:59 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,970 11-22-2023, 11:46 AM
Last Post: aLoop100o
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,096 09-05-2023, 11:16 AM
Last Post: nickolas
  What actions needed to keep on mobian testing user641 3 1,800 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 629 09-01-2023, 11:29 AM
Last Post: Mahgue
  Chatty does not work after suspend mode user641 4 1,892 07-18-2023, 10:43 AM
Last Post: alaraajavamma
