Add contacts with VCF files
(07-17-2020, 01:34 PM)Bouc Wrote: Hi, is there an easy way to import contacts from a vcf file?
I can't use simcard (different format) and I don't want a Google account.
Edit to solve:
From https://wiki.mobian-project.org
Import contacts from VCF file
Syncevolution has been removed from upstream Debian, in the meantime it is straightforward to import contacts from a VCF file via Evolution tooling. First install evolution:
sudo apt install evolution
Before you import the file you will need to set scale-to-fit for Evolution on, otherwise the import dialog page is unusable.
scale-to-fit Evolution on
After this I opened the .vcf file via the Files app, it auto-launched the import dialoug. After importing I removed the Evolution app, this step is optional:
sudo apt remove evolution
sudo apt autoremove
THANK YOU!! Big Grin  It's kind of sad that I still have to do this 2 years later as there's no import button besides using a cloud in gnome-contacts, but I am grateful I am able to import at all
Add contacts with VCF files - by Bouc - 07-17-2020, 01:34 PM
RE: Add contacts with VCF files - by clover - 07-17-2020, 04:45 PM
RE: Add contacts with VCF files - by Bouc - 07-19-2020, 12:44 PM
RE: Add contacts with VCF files - by Bouc - 07-19-2020, 03:39 PM
RE: Add contacts with VCF files - by jjs - 07-19-2020, 09:32 PM
RE: Add contacts with VCF files - by Bouc - 07-20-2020, 01:24 PM
RE: Add contacts with VCF files - by jjs - 07-21-2020, 10:08 AM
RE: Add contacts with VCF files - by Bouc - 07-21-2020, 10:37 AM
RE: Add contacts with VCF files - by Bouc - 07-21-2020, 01:17 PM
RE: Add contacts with VCF files - by Be. - 05-01-2021, 03:22 PM
RE: Add contacts with VCF files - by voidmain - 10-16-2020, 08:02 AM
RE: Add contacts with VCF files - by Gribouille - 11-20-2020, 10:34 AM
RE: Add contacts with VCF files - by kebab - 05-20-2022, 07:26 AM
Exclamation How to play AMR files? anonymous 4 5,416 09-20-2023, 03:48 PM
Last Post: anonymous
  Nextcloud Calendar and Contacts mark1250 3 3,835 12-29-2022, 07:27 PM
Last Post: mark1250
  How to deal with overloaded config files? jsch 1 2,701 10-02-2022, 02:46 PM
Last Post: treebeard
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 9,696 09-30-2022, 08:53 PM
  Deleting telephone contacts Emilio 4 5,421 02-18-2022, 05:43 PM
  no access to webdav files (for some apps) jsch 0 2,460 11-13-2021, 09:46 AM
Last Post: jsch
  Synchronizing: How do you sync / synchronize Calendar and Contacts with your desktop? Anna 15 23,471 11-04-2021, 03:54 AM
Last Post: Maus
Question How to Save Read Only Files, Questions on Location lovepine88 8 13,747 06-12-2021, 06:08 PM
Last Post: ryo
  gnome-contacts not showing call nor sms button cafe 2 4,541 02-11-2021, 01:31 AM
Last Post: cafe
  how to import contacts from sim cards cybercow 7 12,460 12-06-2020, 01:14 PM
Last Post: cybercow
