Mainline kernel not working (no screen)
Hi all,
I successfully started a Debian 10 ARM64 rootfs + initrd, preinstalled using QEMU with LXDE and autologin. For a touch screen this is not easy to use, but I expect using keyboard and mouse soon Smile
Using the 5.6.0-pine64 kernel which was provided with Ubuntu at delivery few weeks ago, having included the 5.6.0-pine64 modules into the debian's initrd, and having the "fstab" file corrected into rootfs, it boots fine. I customised the U-Boot boot script too.
However, I tried to do the same with a 5.8.0-rc5 kernel, using the config-5.6.0-pine64 as .config file for building the 5.8.0-rc5 kernel.
But I have no screen. I tried disabling "Enable loadable module support" so that every driver is embedded/preloaded into the kernel, but nothing more.
When comparing resulting .config, the following lines are missing after having 5.8.0-rc5 kernel built :
CONFIG_CC_HAS_WARN_MAYBE_UNINITIALIZED=y
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_MEMCG_SWAP_ENABLED=y
CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT_VHE=y
CONFIG_ARM64_WORKAROUND_SPECULATIVE_AT_NVHE=y
CONFIG_ARM64_LSE_ATOMICS=y
CONFIG_ARM64_PTR_AUTH=y
CONFIG_PLUGIN_HOSTCC=""
CONFIG_HAVE_MEMBLOCK_NODE_MAP=y
CONFIG_TRANSPARENT_HUGE_PAGECACHE=y
CONFIG_VEXPRESS_SYSCFG=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_SUN4I_CSI=m
CONFIG_VIDEO_SUN6I_CSI=m
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_DRM_PANEL_PINEPHONE_JD9365DA=y
CONFIG_DRM_PANEL_XINGBANGDA_XBD599=y
CONFIG_DRM_I2C_ADV7533=y
CONFIG_SND_SOC_EC25=m
CONFIG_USB_CHIPIDEA_OF=m
CONFIG_RTL8723CS_NEW=m
CONFIG_COMMON_CLK_VERSATILE=y
CONFIG_CLK_SP810=y
CONFIG_CLK_VEXPRESS_OSC=y
CONFIG_CLKSRC_MMIO=y
CONFIG_CLKSRC_VERSATILE=y
CONFIG_RPMSG_QCOM_GLINK_NATIVE=y
CONFIG_OPTIMIZE_INLINING=y
CONFIG_UBSAN_ALIGNMENT=y
I guess the fact of having CONFIG_DRM_PANEL_PINEPHONE_JD9365DA missing may be one of the reasons why I have nothing on the screen...
Are you sure that mainline kernel can really be used on the pinephone?
If so, is there some diffconfig or pinephone64-defconfig somewhere?
Thank you in advance!
Mainline kernel not working (no screen) - by jrobin28260 - 07-17-2020, 06:05 AM
  Mobile internet via cellular network mostly not working Anna 18 10,239 01-19-2024, 02:59 AM
Last Post: anonymous
Exclamation The internal speaker stops working anonymous 6 1,004 01-17-2024, 05:53 PM
  Screen auto-rotation sensitivity mdk 0 268 12-26-2023, 06:08 AM
Last Post: mdk
Big Grin An early xmas present: 6.1 kernel treebeard 28 9,942 07-18-2023, 03:14 AM
Last Post: gischpelino
  how to disable ipv6 at kernel level with towboot? vusra 2 899 07-09-2023, 01:25 AM
Last Post: vusra
  Screen stay black unless power key pressed short freelectro 0 650 06-24-2023, 01:55 PM
Last Post: freelectro
  Unsuspend → Black screen mdk 15 5,178 06-22-2023, 11:20 AM
Last Post: Melechtna
  Stability problems with 6.1 kernel Zebulon Walton 9 2,589 05-12-2023, 08:09 AM
Last Post: zetabeta
  APN settings not working with new operator SIM card user641 1 1,024 03-01-2023, 04:43 PM
  Possible Solution for Microphone Not Working Ferriah 0 947 02-13-2023, 01:09 PM
Last Post: Ferriah
