USB-C Dock and HDMI, revison 1.2 (Modded)
*Edit* Please see https://wiki.mobian-project.org/doku.php?id=mods
Update ANX chip firmware https://xnux.eu/devices/feature/anx7688.html
Note: this should be run as root user and not through sudo
*This line is important. Note 2: Clone the repository rather than directly downloading the .bin file. For some reason, directly downloading it does not give you the correct image and errors on the “echo” command.
*Original Post*
I have been testing out a USB-C dock for a couple days now. USB device work (mouse, flash drives), SD-card reader, and power deliver all work. However, I can not get a monitor to detect the HDMI signal, dmesg shows when HDMI is plugged in an detected. Has anyone successfully used display out on Mobian? I am hitting a wall troubleshooting this, and have ruled out the dock itself.
Unplugged HDMI: anx7688 0-0028: dp state changed to 0x00
Plugged in HDMI: anx7688 0-0028: dp state changed to 0x03
Note to anyone wondering my phone is hardware modded (switches removed)
USB-C Dock and HDMI, revison 1.2 (Modded) - by Ersatz - 07-16-2020, 01:06 PM
  no HDMI (DP) Output over Dock vuj 17 11,041 06-11-2022, 05:51 AM
Last Post: zltpxqhp69o2
  Ethernet through the dock? Diagon 22 19,704 01-25-2021, 01:05 PM
Last Post: zborgerd
  screen goes blank when I insert pinephone dock, or usb-a to usb-c adaptor rp3 3 3,414 01-12-2021, 05:06 AM
Last Post: rp3
  HDMI on Mobian sundog 2 3,172 09-08-2020, 09:19 AM
Last Post: sundog
