Turn by Turn alternative GPS app in Mobian
(08-20-2020, 06:50 PM)bcnaz Wrote: This seems to only function with internet access, ( cell data, or wifi seems to work )
is that only for the map(s)  or is there a true GPS within the modem ?
The refresh periods will determine if you can use this for distance calculations such as speed.
Would it be possible to pre-load maps ?  ( Like my old Garmin hand held GPS used to do )
So far when I attempt to use the app on my phone, it sometimes shows my exact location within my house
While it also sometimes shows me 5 miles away on the side of a mountain. ?  Very Inconsistent  !
I haven't tried using it truly offline yet, but from what I can tell it operates on map data you download into your device from a few different sources, such as openstreetmaps. GeoClue will need internet to do any geolocation without GNSS/GPS. However, it should pass on through satellite location if it is able to get a fix on your position with a nice clear view of the sky.
I have added my working (mostly) configuration and more details to the mobian wiki here: https://wiki.mobian-project.org/doku.php?id=navit
RE: Turn by Turn alternative GPS app in Mobian - by newton688 - 08-20-2020, 07:50 PM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 24 2,401 Today, 07:42 AM
Last Post: zetabeta
  Mobian repository status henrythemouse 16 8,941 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 150 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,864 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,038 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,933 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 647 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 3,077 06-19-2023, 03:02 PM
Last Post: vusra
