Turn by Turn alternative GPS app in Mobian
I have maps working on Navit. This issue is because the Debian packages don't contain the layout xml files needed to display the maps.
You need to grab a layout file like car_android_shipped.xml and edit the navit.xml line that has the NAVIT_SHARDIR variable at the bottom to point to the dir with the layouts in. e.g.
<xi:include href="/home/mobian/Documents/navit.maps/layouts/navit_layout_*.xml"/>
To make it look extra cool you can set up the font and icon sizes. This is the line I'm using
<gui type="internal" font_size="300" fullscreen="1" icon_l="128" enabled="yes">
Also set up a custom osd description. I used This Layout as a test and it worked pretty well.
[Image: uyadrUQ.png]
Now we can talk about getting gps in to it. Everyone seems focussed on Navit allows gpsd, but it also works with serial devices https://navit.readthedocs.io/en/latest/c...x.html#gps Maybe a named pipe from mmcli, or some other stupid idea!
Edit: have put in a GeoClue integration request with navit https://github.com/navit-gps/navit/issues/1032
Edit2: Upstream packaging bug https://bugs.debian.org/cgi-bin/bugrepor...bug=967960
RE: Turn by Turn alternative GPS app in Mobian - by Baggypants - 08-05-2020, 12:09 PM
  Mobian repository status henrythemouse 16 8,537 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,815 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 112 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,885 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,766 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 616 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,799 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,872 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 614 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 2,964 06-19-2023, 03:02 PM
Last Post: vusra
