Pinebook Pro sometimes Does not boot up correctly
I recently installed Arch Linux on my Pinebook Pro. /dev/mmcblk2p1 is my boot partition and p2 is my root partition. The problem is that sometimes Linux cannot detect /dev/mmcblk2p2. Sometimes, it works fine. Here is the output:
Quote::: running early hook [udev]
Starting version 245.6-8-arch
:: running hook [udev]
:: Triggering uevents...
Waiting 10 seconds for device /dev/mmcblk2p2 ...
ERROR: device '/dev/mmcblk2p2' not found. Skipping fsck.
:: mounting '/dev/mmcblk2p2' on real root
mount: /new_root: special device /dev/mmcblk2p2 does not exist.
You are now being dropped into an emergency shell.
sh: can't access tty; job control turned off
[rootfs ]#
It was working fine a while ago, it only happens sometimes. Using UUID on the extlinux config also results in the same.
I had recently soft bricked my PBP and had to switch off the emmc but it is fixed now, if that is relevant.
Apparently running:
Quote:echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
As suggested by randomuser987987 in the thread Pinebook Pro dead after updating u-boot works in getting the partition to show in /dev. The question is will the changes persist forever?
(07-15-2020, 08:50 PM)decisivedove Wrote: Hi,
[rootfs ]#
Apparently running:
It turns out that the changes do not persist. It only works when it wants to. Is there any way to make these changes persist permanently?
Pinebook Pro sometimes Does not boot up correctly - by decisivedove - 07-15-2020, 08:50 PM
  Debian on Pinebook Pro u974615 7 847 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,458 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,081 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,163 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 88,059 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,177 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,163 08-31-2023, 04:20 PM
Last Post: TRS-80
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,949 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,453 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,531 08-07-2023, 01:12 PM
Last Post: myself600
